High Qts woofer enclosure
Old 2nd December 2008, 10:31 PM   #1
pelanj is offline pelanj  Czech Republic
Question High Qts woofer enclosure
I would like to try something like Carlsson Sonab OD-11 - http://www.carlssonplanet.com/od11.php or V1 - http://www.carlssonplanet.com/v1.php
My problem is that all cheap to get FR or car coax drivers I would like to try out first have a quite high Qts and I am afraid of boomy bass. How to overcome this? I was thinking about some resistive vent to make it more damped instead of a closed box. Or make large openings on the sides to make it quasi-open baffle. The boxes should stand on the floor. Could something like that work?
Old 2nd December 2008, 11:20 PM   #2
Drew Eckhardt is offline Drew Eckhardt  United States
Default Re: High Qts woofer enclosure
Originally posted by pelanj
[B]I would like to try something like Carlsson Sonab OD-11 - http://www.carlssonplanet.com/od11.php or V1 - http://www.carlssonplanet.com/v1.php
Equalization. Commercial analog or DSP based parametric, computer with sound card, edit the tracks you want to audition and write to a CDR, op-amp based gyrator and shelving filter or Linkwitz Transform circuits on a breadboard...
Old 3rd December 2008, 12:22 AM   #3
GM is online now GM  United States
GM's Avatar
Works for me.......
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 3rd December 2008, 08:22 AM   #4
Yes, I forgot about the EQ way Anyway, I will try out all three ways when I'll have the possibility.
High Qts woofer enclosureHide this!Advertise here!
when designing a 2 woofer enclosure... slicemaster101 Multi-Way 33 5th April 2012 05:55 AM
SUB woofer enclosure size sumovanner Subwoofers 3 4th December 2008 04:32 PM
fe126e 2 way enclosure with woofer lionking7 Full Range 21 26th July 2008 03:25 AM
Small Enclosure Woofer h_andree Multi-Way 5 28th March 2008 09:25 AM
Please recommend enclosure for this woofer Cro maniac Multi-Way 3 4th August 2004 12:22 PM
Copyright ©1999-2017 diyAudio
