Maybe a stupid question but I have to ask, when will a 6.5 inch driver drop in bass response in OB. I have Seas magnesium in mind. THX
#2 |
RIP
It depends on the width of your baffle, and your driver's Qts. My current test mule, with a ~ 23cm main baffle (with tapered wings forming a quasi U baffle), rolls off at around 200Hz. This is a function of the baffle and the fact that the Qts of the driver is .28.
hope this helps |
#3 |
Yes it did help me
#5 |
I've tried multiple times with 6 and 5" drivers in OB. In short: They don't work. There is simply *no* bass and I'm talking eq-ed xo. Perhaps round 300-400hz rolloff.
On the other hand 10" is fine even with smallish (28cm) baffle. EQ-ed of course.
http://gainphile.blogspot.com |
#6 |
Right.
For OB you need to move a lot of air. The little drivers just don't. 1x12" or 2x10" is pretty much minimum for OB.
Take the Speaker Voltage Test! |
#7 |
I've tried a single 8" fullranger in a baffle of 120cm x 90cm. After 15dB of boost, it's quite 'listenable', but in a very small space and very limited SPL. (the cone moves a lot when playing bass-heavy passages)
#8 |
RIP
The question is - did the original poster intend to use a 6.5" driver as a "bass" driver or was he only wanting to know the useful lower range of that driver?
#9 | ||
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#10 |
My intention was to use it with a subwoofer and it seems I would need one for each speaker
| looking for a small 2" or 3" driver with poor bass response | space-cake | Full Range | 3 | 27th December 2007 01:16 AM |
| AudioXpress August 2006 - "Equalize the Bass Response of Your Room" | ergo | Multi-Way | 0 | 12th April 2007 07:35 PM |
| 10" basS/mid for "party-speaker" | TroelsM | Multi-Way | 0 | 16th September 2005 11:14 PM |
| measuring speaker respone | gjeff80 | Multi-Way | 9 | 28th August 2005 07:40 PM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| Page generated in 0.10448 seconds (78.27% PHP - 21.73% MySQL) with 10 queries |
