Dear all,
I'm a new memeber of this forum, first of all I say hallo! to everybody. I need your help, I'm an Italian audiophile but I love to build something, very often results are not very good, but this time I would like to build a very good pair of speakers, starting from the combo tweeter T330D dynaudio and the midwoofer MW 170. I've already bought both components (an offer...) so I would like to start from them to buid around them my speakers. MW170 is similar to old 20w75 esotec midwoofer, impedance is 8 ohm, technical data are visible here. My ideas is a sealed floorstanding speaker with a volume of 60 liters, what do you think about it??? About filter my idea was a first order filter, similar to that one used in the Dynaudio Confidence 3, crossover frequency at 2600Hz...maybe too high for the MW170. Now I would like to receive your opinion, impressions and anything you have to say about my project. Thanks in advace, ciao Massimo |
#2 |
ciao Massimo,
interesting project. Not so easy anyway. 60 liters appears excessive........ The esotar is very robust, crossover is possible but not sure about how good the system can sound. Hystorycally, those 2 way with "big" midwoofers and simple filters are not so easy to work with. Sonus Faber Extrema , just for example, not so musical as a Minima .............Do you have datasheeet with frequency response on axis and off axis for the woofer ( is it a car woofer, no?)? Cheers, Paolo |
#3 |
I wouldnt use the mw170s for midrange, so far all of the dynaudio automotive range drive units that ive seen have had much stiffer suspention compared to the normal range and sounded a bit different.
Ive heard a system similar to what youre planning but with two d52af domes and four 20w75s and which were integrated well and sounded great. From memory he was using somewhere around a 35l box for two 20w75s which apparently went down to 30hz 3db down. |
#4 |
Hi, MW170 response is in attached, I'm planning to use a D54 as medium, in order to allow a better performance to MW170...this is my idea after heard your (and other) opinions.
Thanks...any additional idea is welcome! Massimo |
#5 |
Hi barnabam,
I use the Esotars with a DEQX HDP3. I've found the best results with a linear phase filter at 48 dB per octave, but, surprisingly, although with such as steep slope you'd think I could cross over low (I've even tried 1250 Hz, a bit like Seigfried Linkwitz's 1400 Hz on the Millenium), which certainly sounds good, in my opinion it sounds even better at 2500 Hz, with the same steep filter. i.e. I'd be a bit worried by a shallow filter at 2600 Hz (even if Dynaudio themselves do it). I suppose a lot depends on the dynamic range intended. David
D OB G |
#6 |
Massimo,
Those graphs are nearly invisible, too little 3 Ways? How is your designing speaker experience? 3 ways is complicated, imho 2 way is a lot more easy. That woofer is not so bad, maybe you can push the tweeter at 2K, as SF and others have made in the past Do you listen at very high levels? Cheers, Paolo |
| WTB Dynaudio Esotar T330D Tweeter | slhijb | Swap Meet | 3 | 16th February 2012 05:28 PM |
| WTB Esotar T330D | rush1 | Swap Meet | 0 | 20th March 2009 10:48 AM |
| Dynaudio Esotar T330D Datasheet - Where to find? | HiFiNutNut | Multi-Way | 5 | 6th January 2007 10:06 AM |
| FS: 1pr. Dynaudio Esotar T330D | sacarmic | Swap Meet | 0 | 22nd November 2006 03:39 PM |
| FS: Dynaudio ESOTAR T330D + ESOTAR M560D | zino | Swap Meet | 2 | 17th May 2004 11:55 AM |
| Page generated in 0.10313 seconds (77.56% PHP - 22.44% MySQL) with 11 queries |
