Banned
Being very much a learner in this game, I looke at the specs of many woofers for use in an active 3 way system. The bass for most seemed lacking and while looking at sub-woofers, the question came up; why not use a sub-woofer in lieu.
The drivers I am interested in are; Peerless 830843 Datasheet Used with a 54-55 litre closed box, there is good bass according to WinISD. Vifa PL11MH-09-08 bass / midrange Datasheet Current VIFA tweeter until something strikes my fancy. The 830843 seems to have enough response for a crossover at 300-320 HZ which the mid-range is comfortable with. High pass will be 3000-3200Hz. Being active, matching sensitivities isn't an issue. My question; is my logic sound or is there something that won't make it work? Frank |
#2 |
There is nothing stopping it working with the corrrect active c/o that produce the correct acoustic responses and roll-offs for each driver, these will not be "standard" active filter functions. http://www.rjbaudio.com/Audiofiles/FRDtools.html http://www.geocities.com/woove99/Spk...esigningXO.htm http://www.zaphaudio.com/ http://www.rjbaudio.com/projects.html http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://www.humblehomemadehifi.com/ http://htguide.com/forum/forumdisplay.php4?f=39 http://www.linkwitzlab.com/ http://www.geocities.com/kreskovs/John1.html |
#3 |
Banned
I should have been clearer. The active cross-over is 24 dB per octave.
Frank |
#4 | |
It does not work like that. Standard filter functions with no EQ rarely work well. Proper active filters are the target filter minus the acoustic irregularities and roll offs such that the acoustic response meets the wanted target, e.g. 4th order L/R. You can include standard filters in modelling but your results will not follow the standard filter functions. Minimum "extra" to add would likely be some passive line level EQ for shaping. Using 4th order L/R electronic and matching drivers levels is a short cut to some form of adequate, it is not "correct". |
#5 |
Banned
Hi sreten and thanks,
This is the crossover I will be using; Rod Elliott's L/R crossover which is, I believe, fourth order, has an adjustable output buffer. Having looked around a bit more, I'm now tending to the Visaton TIW 250 XS 8 OHM Data page in a 55 litre vented box as per the web page. All the design work is done Frank |
#6 |
Regarding you first suggestion, a peerless sub
I would look closer at XXLS 12" 830952, that one hits 20hz with ease, but needs a big box Fore higher midbass your Visaton choice probably works better |
#7 |
Banned
Thanks tinitus,
12" is too big for the size box in a fairly small room. I don't think that I could get it past my wife either. Frank |
#8 | |
Hi, It is not the proper way to do it. See Linkwitz's and Kreskovsky's stuff on active XO's in the links I previously posted. |
#9 |
the other alternative is trade the wife in for something more agreeable cheers chutzpah
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#10 | |
Banned
The current setup is: Tweeter Vifa D25TG-55 1" dome Midrange Peerless 832873 5 1/4" Woofer Peerless 830868 8" The difference over the passive setup is chalk and cheese. Frank |
| Anyone know specs for peerless woofer? | Jimmy154 | Multi-Way | 30 | 20th April 2012 11:46 PM |
| Peerless 10" XXLS 830843 | burger007 | Subwoofers | 6 | 27th July 2009 07:32 PM |
| Peerless woofer and PR | greg_mcquaid | Subwoofers | 10 | 22nd November 2005 08:09 PM |
| Another Peerless woofer Question (CSX-10) | LageB | Multi-Way | 4 | 26th April 2003 05:48 AM |
| Peerless Woofer | kinsale11 | Multi-Way | 2 | 28th July 2002 02:18 AM |
| Page generated in 0.11066 seconds (80.34% PHP - 19.66% MySQL) with 11 queries |
