Hi i'm thinking about making a pair of new speakers and i was wondering if the units that i've looked at would be a good fit for each other.
tweeter: Vifa XT25BG60-04 Link Bass: Peerless XXLS 830847 Link Midrange: Peerless HDS 830875 Link i also considered the little brother of the midrange unit, but discarded the idea because of lower effiency I were thinking of making the crossover point at 300/2500hz does anyone know a reason why this would't work well together? Best regards |
#2 |
Hi
Very good driver choices for your crossover targets. 1) The vifa tweeter should be better at the 8 ohm version instead? 2) Woofer is a DVC in parallel at 3 ohm, s/b easier to implement BSC designs. Should be fine using high current amplifiers. If you are using bass reflex the port will be around 45 cm long. http://www.tymphany.com/830847-app-note 3) Excellent 8 ohm midrange. Easier to cross at 2,5K than the phase plugged version. Not as good at LF distortion, but less an issue here if crossed at 300Hz. edit> oops just realized you have 2 mids for MTM, so use 4 ohm all around then. Now a MTM wants at least a 3rd order response at a freq probably lower than your than your target. Xover to the tweeter at a freq. related to the spacing of the mids.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 |
a 12" xxls used to 300Hz ???
#4 | |
crazyhub |
#5 |
i would have used a sealed box and this woofer
http://www.tymphany.com/830669 if it was Me/ but I have no personal experience with these particular drivers, I just looked at the break-up peaks and dips and thought that 120Hz tops for the XXLS A pair of these would however need a bigger box than 1 X ported
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 |
there is way more to it than piston range.. the main issue is what it will sound like !!
If he thinks he can make an XXLS sound decent up to 300Hz.....OK. ![]() Its just not something I would attempt. |
#7 | |
crazyhub |
#8 | |
I think 3rd order filters at 1.8~2.0KHz with closest spacing between mids would be advised. Then your tweeter might not like that tho see D'Appolito MTM http://www.parts-express.com/project...project=USHERs search http://www.google.com/search?hl=en&q...earch&aq=f&oq=
#9 | |
#10 | |
that would make the box to big |
| Page generated in 0.10235 seconds (81.16% PHP - 18.84% MySQL) with 9 queries |
