Old 29th November 2008, 12:38 PM   #1
kamppi is offline kamppi  Finland
Default Jay's ER18RNC_27TDFC finished
Finally I finished my tube friendly speakers. I got them ready on last night 1 am. My daughters were sleeping, so I could not test them too well. This morning I listened to them for a while. Speakers and amplifiers are still running in, but I am already now very satisfied with the sound. I must admit that I am positively surprised about the result.
Earlier I had ZD5. These speakers are very easy to listen to and I can focus on and the music. Music just flows, also on low volume levels. Soundstage is deep and wide and this is exactly what I expected and hoped for. Immediately noticed that low end is controlled and deep enough.
I used the original XO which is available on Jays webpage. First I will let the system run in before I decide, If I need to modify the XO based on Jay's suggestions. For sure I will change the series capasitor on tweeter to better one. Now I have AudynCap KP-QS, which is not the poorest one, but I know that there are better ones available. When I know which value I want to use, I will buy ClarityCap ESA capasitors.
Thank you Jay for sharing this design on the global audio community. I think that you can be proud of your designs, specially if other designs are as good as ER18RNX / 27TDFC MTM and this speaker is excellent. I think that it gets even better and better while it is breaking in.
Thank you Mike Carrick for sharing your experiences and I have got many valuable hints from you I really value your help.
I am not totally satisfied with the woodwax on the speakers. I did quite comprehensive sanding on the cabinets and it feels like that the woodwax is floating on the surface.
When I tried same woodwax on the surface which was not sanded at all, the result was more satisfying.
Old 29th November 2008, 07:07 PM   #2
ific is offline ific  Argentina
Congratulations!
Would you like to make a comparison between this speaker and the ZD5?
Thanks in advance
ific
Old 29th November 2008, 10:33 PM   #3
blue934 is online now blue934  Canada
that looks great kamppi! i'm working on a set of jay's usher 2 ways so will be interested in your comments once you have yours dialed in. interesting finish, what is the veneer?
blue934
Old 30th November 2008, 01:47 AM   #4
Thread header is wrong. It should be ER18RNX, not RNC.
Both ZD5 and Jay's ER18RNX / 27TDFC MTM are excellent speakers. I can not say which one is better and these speakers are different. I wanted to try tube amplifier and I bought one. ZD5 can not really be used with tube amplifier and Jay's ER18RNX / 27TDFC MTM is very suitable for valves.
Speaker cabinet is build of birch plywood, I have not added veneer. I applied dark brown 'Clou' woodwax on the speakers.
Osmocolor woodwaxes are great and easy to use. Clou is also quite easy, but not on sanded suraces.
I put 3 - 4 mm bitumen pads on every wall.
Old 30th November 2008, 02:55 PM   #5
wigginjs's Avatar
kamppi:
I don't suppose you would be interested in hooking the ZD5 and Jay's design up to the same solid state amplifier and giving some listening impressions?
The Four Chairs
DIY Home Theater
Old 1st December 2008, 07:17 AM   #6
Luckily I can save myself from this subjective comparison, cause I do not have ZD5's anymore. Friend of mine was eager to buy them
/Jarno
finished sub chainenoble Subwoofers 2 20th September 2007 07:11 PM
Finished Sub eag Subwoofers 5 19th April 2006 10:09 PM
Finished my GC! drfrink24 Chip Amps 19 17th March 2005 01:58 PM
25W almost finished iceman Solid State 6 8th September 2003 02:57 PM
Here's my finished DIY (yet another one...) ChesterFuzzin' Multi-Way 2 22nd April 2003 05:02 PM
Page generated in 0.08857 seconds (75.91% PHP - 24.09% MySQL) with 11 queries
