I am kind of new to fine audio. I have a pair of Tannoy 609s which are just fine... but I am wondering whether there's another Tannoy model which might make a sizeable improvement over these already good 609s.
I have already messaged with a member on this site named Martin and we have established the 615's with their improved bass are not worth considering, because I already have a decent sub. Would anyone on this site like to message with me about other used Tannoy models? (I could never afford new high-end Tannoys.) I want to run them with an 18 watt valve amp. Tannoy has very recently advised me that for my audio room dimensions (16 feet by 11 feet by 8.5 feet) that 10" drivers would be optimum. Has anyone had positive experience with such a model which you would like to share, re. speakers I could look for on the used market, not very old ones but say built in the 1980s or more recently? Thanks in advance, Neil |
#2 | |
The CPA-12 is also one to consider, though it gives up a solid octave of bass compared to the 12 DMT II. (If you use subwoofers, it wouldn't be a problem.) If you need something prettier, the Saturn S8 or S10, D500, D700, and D900 should all be steps up. IMO, those era Tannoys are better-sounding than most of their current line. Except the Glenair 10 and 15, which not coincidentally are the only modern Tannoys that I've heard that don't use that dumb supertweeter. Oh, and Tannoys, like all speakers, will probably sound more accurate (though not necessarily "better") with a more powerful amp. |
#3 |
Hi Pallas,
I appreciate your response. (And my thanks again to Martin for his earlier guidance on this topic.) I will get back to you at greater length after I do the research on the many models you have mentioned. Until then... Thanks again, Neil |
| tannoy 615 mk 11 | tricia | Multi-Way | 0 | 26th July 2009 10:12 PM |
| Tannoy 609 compared with Tannoy 615 | photomusicfreak | Multi-Way | 4 | 27th November 2008 10:27 PM |
| 41Hz AMP2 upgrade... What parts to upgrade? | MotoMan_Yz400 | Class D | 2 | 6th March 2008 05:28 AM |
| Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? | jpchleapas | Digital Source | 1 | 31st January 2008 07:18 PM |
| Replace or upgrade Mid/Bass on Tannoy R1 | mcai7et2 | Multi-Way | 1 | 24th February 2003 10:08 PM |
