DIY Speaker Binding Post
Old 5th April 2003, 11:20 AM   #1
corbato is offline corbato  India
corbato's Avatar
Default DIY Speaker Binding Post
I hope this is the right forum for this thread.
Here are my plans for a DIY speaker binding post. II can see questions being asked as to why DIY such a thing. Especially when a pair of Cardas is available for $25 or so. Yes, but not so in India. You have to import the stuff and pay custom duty etc that will push the cost to stratospheric limits. So here we are, a quality binding post for less than Rs. 100 each (around US$ 2).
Old 5th April 2003, 11:21 AM   #2
corbato's Avatar
The shaft ...
Old 5th April 2003, 11:23 AM   #3
corbato's Avatar
...and the Nut
Old 5th April 2003, 11:27 AM   #4
corbato's Avatar
The material will be pure copper bar. I am thinking of either gold or silver plated, but I suspect bare copper will sound better. A pair of them will be mounted in a 2 x 3 insulated acrylic board. All machining will be done in a CNC. I am also attaching the CAD drawing if anybody is inclined to play around.
Comment please
Old 5th April 2003, 11:29 AM   #5
corbato's Avatar
sorry the AutoCad drawing doesn't attach..
Old 5th April 2003, 12:47 PM   #6
Milzie is offline Milzie
You must have a killer PC.
We never bother to model threads as the rendering goes all choppy when you rotate, pan, or zoom.
Those look good, but take a look at www.cardas.com you may be able to buy them for less than you can build them. They have the same binding posts.
Jeff
The *** is a muscle that MUST be rested!
Old 5th April 2003, 01:36 PM   #7
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
DIY Speaker Binding Post Send a message via AIM to Peter Daniel
He said, he expects the cost to be around $2. It is much less than Cardas. Comparing to Cardas, yours don't accept banana connectors, but this is not a big problem.
To order kits contact me through forum mail.
Old 5th April 2003, 01:58 PM   #8
corbato's Avatar
Thanks for the comments
Not quite..a vanilla PIII. AutoCad 2000, and SolidWorks for simulation.
Originally posted by Peter Daniel
... don't accept banana connectors...
As you rightly said, that isn't too much of a worry. I plan to use copper spades.
The Nut will have nurling edge. In the rendering I've missed out the retainer nut for the inside. But I need to know if the basic design is ok. Have never seen a Cardas.
Also, can some one confirm that uncoated copper should be better than Gold or silver coating. I don't see oxidation in copper as a major issue.
Thanks again.
Old 5th April 2003, 02:05 PM   #9
Mattyo5 is offline Mattyo5
Send a message via AIM to Mattyo5
Those look great...you've inspired me. I'll have to get some copper stock and go crazy on my grandfathers lathe!
Quick suggestion maybe. On the shaft... i noticed it's completely round. What you might want to do...is make that biggest diameter HEX instead of round so that you can attach a wrench to it when you are securing the shaft from the inside. Otherwise...when wrenching a bolt on from the inside...you won't be able to grab it easily.
Good luck!
-Matthew K. Olson
Old 5th April 2003, 02:12 PM   #10
corbato's Avatar
Originally posted by Mattyo5
.... make that biggest diameter HEX...
Yes that did cross my mind, but I wanted to keep minimum number of operations. Perhaps I can grab the shaft with plier while tightening it.
DIY Speaker Binding PostHide this!Advertise here!
Binding Post Crossthread, Help!! dmongrain Parts 6 23rd February 2009 08:27 PM
binding post yuval Chip Amps 1 19th May 2004 02:40 PM
WBT speaker binding post TPC Parts 1 24th April 2003 10:25 PM
