DIY mini speaker project
Old 25th November 2008, 10:41 PM   #21
chicks is offline chicks  United States
Read this thread, especially post #5:
http://www.diyaudio.com/forums/showt...184&highlight=
Old 26th November 2008, 12:05 AM   #22
Driver_King is offline Driver_King  United States
Any ideas as to where I can attach the sub to the amp and where to put the plate amp? Also, should I go for the passive crossover instead to avoid cutting out a hole and adding an extra power cable? Where inside could I put the sub? Sorry for all the questions.
Old 26th November 2008, 01:28 AM   #23
There's no way to add a subwoofer inside this unit, it would need to be external.
While it's possible to do a passive sub, you'll get much better performance with a powered one. The price differential on the Parts Express site was a buck or two.
You could easily add wires from the internal speakers to the plate amp speaker-level inputs without cutting a hole, just pass them out the back through the bass reflex port.
However, this unit will no doubt give far better bass as-is compared to the unit you showed earlier, possibly enough to satisfy without mods.
If you're up for a real fixup project, here's a unit with a built-in sub and a bit more power - just doesn't work http://www.stootsi.com/store/item.aspx?item=81433349
It's for an iPod, not a PSP, but you can always go the aux jack route...
Old 30th November 2008, 02:14 PM   #24
adason is offline adason  United States
adason's Avatar
Driver_King, here is the smallest "subwoofer" I have ever seen
http://www.parts-express.com/pe/psho...TOKEN=95552386
Old 30th November 2008, 03:07 PM   #25
It only goes down to 90hz though...
Old 1st December 2008, 05:16 PM   #26
adason's Avatar
what do you expect from 2" speaker
I thought that you are trying to do as small as possible, hence the name of thread "mini"
Old 1st December 2008, 06:03 PM   #27
I didn't say I was looking for a 2" though. I was looking at a 3" for the speakers I already had and was wondering what people thought of them. Sorry for the confusion. I may still end up reusing the current system I have for it (the pic I posted earlier is what it looks like) but may modify it so it can power a "sub." I also wanted to know where would be the best place to put it and if it was possible to put it in the case without building a separate enclosure and if it would fit.
Old 1st December 2008, 06:30 PM   #28
troystg is offline troystg  United States
troystg's Avatar
Well I need to say thanks. I just bought my son one of those docking stations for his PSP.
Troy
Thinking positive doesn't make things better, it makes you a better person.
DIY mini speaker projectHide this!Advertise here!
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
Mini cum laude 3-way project thread max_andrews Multi-Way 22 4th February 2008 09:24 PM
Mini Statements DIY speaker project is finished! jholtz Multi-Way 0 11th September 2007 09:44 PM
simple PC mini-amp project ? jives11 Chip Amps 11 7th January 2005 01:05 PM
Mini-Monitor Project Going On gary f Multi-Way 29 20th March 2004 03:45 AM
