Hello Everybody,
I've just recently constructed a pair of loudspeakers, the old style floor standing 12" woofer/mid/tweeter box type, and I'm quite happy with them, except for one thing. After a few days, I noticed when I'm listening to a recording with an electric bass, the bottom E doesn't seem to be as loud as it should. Like James Taylor's "Carolina on my Mind", the bass player slams the low E about 30 seconds into the song, but it just sounds lightweight and hollow to me. The speakers are built around Dayton's 12" Classic woofer, in a 3.8 cu. ft. enclosure, with a 4" wide X 6.3" long port. I made sure the boxes are air tight. I played a bass guitar for several years and realized that the lower notes are louder because the strings are larger....simple laws of physics. I'd like to play around with the length of the port, but I'm not sure which way to go. |
#2 |
You'd probably need a much longer port. OTOH that classic Dayton woofer doesn't have much xmax so be careful.
DIYaudio for President ! |
#3 |
Tuning seem fine for 40Hz, but lower tuning is possible. Your problems may relate to baffle step compensation. For a typical 3-way the bass drivers needs to be ~ 4dB more sensitive than the midrange and treble for even tonal balance. |
#4 |
The boxes are pretty wide....18 inches. Do I still need BSC?
~~John~~ |
#5 |
e.g. : http://www.t-linespeakers.org/tech/bafflestep/
and : http://www.tolvan.com/edge/ also : http://sound.westhost.com/bafflestep.htm |
#6 |
I did build a baffle step correction circuit that I incorporated into my amps, and it works well. (I believe it sounds better than physically padding the tweeter). I'm (not totally) happy with the quality/quantity of the bass response. It's just that the bass seems to drop out around the low E frequency of an electric bass. I find that strange, considering the size of the woofer and enclosure.
#7 | |
If yes, your tuning "seems" fine, as sreten said. It could be a room issue. Try moving the woofers around the room, or try it in another room. Is your ceiling about 7 feet high ? Is your woofers approximately 7 feet from the wall ? Try positioning it around 14 feet from a wall to boost ~40 Hz. I hope it will work... Good luck !
#8 | ||
#9 | |
OTOH, room dimensions can cancel and boost some frequencies relative to others. You can look at this document to have an idea : http://www.padrick.net/LiveSound/CancellationMode.htm That's why I suggest you to try another room or move the speakers around to be sure, since your tuning seems perfect to play Low E, if we talk about the same 40 Hz low E.
| Bottom Audio 200 | plovati | Clubs & Events | 3 | 8th April 2009 03:49 PM |
| The 'bottom end' | PeteMcK | Everything Else | 0 | 18th September 2008 07:18 AM |
| Venting sub out bottom... | Godzilla | Subwoofers | 0 | 5th August 2008 10:55 PM |
| What's lurking at the bottom? | GlennME | Multi-Way | 10 | 21st August 2002 10:52 AM |
| Page generated in 0.10378 seconds (82.63% PHP - 17.37% MySQL) with 11 queries |
