Hi, I need advice on D6.8. How much does it give the internal volume cabinets? I saw him from 12 to 25 liters. What is the best? As the height of the Q1R. Nowhere on the Internet, I found no DIY project with the loudspeaker. It just uses the company Totem Acoustic. Thank you for your reply.
#2 |
I've personally tried a sealed 11litre (probably 10l actual volume if you consider the driver displacement) box with the D6.8s and found the bass to be quite punchy without much depth.
I then drilled a 3/8" hole at the back of the enclosure ala avalon audio monitors and found that the hivis gained some depth. The eventual enclosure had a pair of 50hz ports but stuffed so it is aperiodic. I prefered this than having the ports unstuffed but it might be due to an incorrect port tuning. It needed a good 100watts at least in that kind of box for a fairly small 12' x 11' room to play loud.
C h r i s |
#3 |
here's a link to a Swans design. it took some digging but i thought i had seen that combo somewhere. i can't translate it from chinese but the essentials are there.
http://www.hiviresearch.com/product/...ew.php?id=1135 blue934 |
#4 | |
#6 |
Thanks a lot for the answer. How will the project finished, I will photograph here. I amplifier NAD C355BEE
| HiVi b3n | pheonix358 | Multi-Way | 3 | 20th June 2009 11:24 AM |
| HiVi B3S (UK, EU) | jimbo1968 | Swap Meet | 9 | 17th May 2007 03:31 PM |
| HiVi M5N or M4N | guru_jeff | Multi-Way | 0 | 8th October 2006 05:45 AM |
| Hivi Q1R | Phlim | Multi-Way | 2 | 21st July 2006 08:49 PM |
| Hivi Dmb-a | ypasco | Multi-Way | 0 | 18th November 2005 06:54 PM |
| Page generated in 0.07779 seconds (75.88% PHP - 24.12% MySQL) with 10 queries |
