Build Replica IMF Transmission Line Speakers??? - Page 2 - diyAudio
Old 24th November 2008, 12:30 PM   #11
AMV8 is offline AMV8  United Kingdom
Hi
My experience is that the T27 goes with the B139/B110 better than the Celestion HF1300 does. Also if you use the T27 I do not think that you really need the super tweeter as the T27 goes very high on its own.
Don
Old 24th November 2008, 07:55 PM   #12
Default transmission line
Hi Don
You may be correct in what you say but i am trying to emulate the original design as close as possible at the moment and then improve on it.It is my intention to replace the 8ohm hf1300 with 2 x 16ohm hf1300s in parallel.I have listened to this setup in the ditton 25s and they are superb for upper mid range speakers, i wll then turn my attention to the b110 for a further improvement.
Tony
Old 24th November 2008, 09:00 PM   #13
frugal-phile(tm)
planet10's Avatar
Default Re: transmission line
Bad idea. The spacing of 2 is way too far apart at those frequencies to avoid combing. In the Ditton this causes a muddled HF (the HF1300s don't get anywhere near the midrange)
You'd be streets ahead to just replace the tweeters with a single modern tweeter -- even a modest modern tweeter can handily outperforn the tweeters of the day.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th May 2010, 06:06 AM   #14
cdfac is offline cdfac  United States
is there still a plan for the RSPM or SACM cabinets floating around? i've looked and can't really find anything useful. i've got the spare drivers to do a 3-way speaker like this, and i was thinking of modeling it after the SACM form factor. i'd appreciate any help i can get here, thanks!
Old 4th May 2011, 05:26 AM   #15
mikemac is offline mikemac  Australia
mikemac's Avatar
Default IMF question
This is an old thread but i am interested in building some thing more substantial than my Kef duettes. I have some scandyna a-25's and no partner so a very large transmision line like the one in planet-10's post sound like the go.
I have some questions: Am i to understand that i build the cabinets, use my seas woofer and a suitable mid range driver ( i have some fostex fe-103's??) and then mount an external tweeter, build cross over and bob's your uncle.
I am pretty savvy with electronics but a complete innocent with acoustics so any thoughts or suggestions would be very much appreciated
Michael
Old 4th May 2011, 06:13 AM   #16
frugal-phile(tm)
planet10's Avatar
If one assumes that the old scandyna is similar to the current variation the line Scott & i did for the world design lit should work fine. With FE103 (or any number of 3 or 4" FRs) a tweeter is optional. If you leave off the tweeter and do an active XO you'd be in your comfort zone
Old 4th May 2011, 06:43 AM   #17
mikemac's Avatar
Thanks for that. I am keen to get on with this. i will be back to get some advice on the xo design. let u know what happens
michael
Old 5th May 2011, 02:58 AM   #18
mikemac's Avatar
One very last thing, does any one have a ply cutting plan for the above mentioned Viking TL? It would be much appreciated. Kind regards Michael
Old 15th May 2011, 01:28 AM   #19
speakerman19422's Avatar
Gone are the days of the Fried transmission line kits designed by Bud. The new company has left out the DIY.
0 Phase Constant Voltage Series Crossovers.
1/4 W T-lines for Satellites and Subwoofers
Old 28th December 2011, 04:28 PM   #20
krigby is offline krigby  United States
Send a message via MSN to krigby Send a message via Yahoo to krigby
I have been searching for a good TL cabinet design for a 3-way active speaker system for a while and the Pro9 looks like a good candidate.
I have a pair of Mark Audio CHR70's and a pair of Fostex FE126En's laying around. I was thinking I might use either of them (preferably the MA's) for the mids.
My vision is to use the miniDIGI/DSP/AMP combo in 2.1 mode, but that means I am going to need some really efficient woofers since the miniAMP only delivers 20 watts.
Any thoughts on this concept? Any suggestions on bass drivers for the 3-way Pro9 cabinets?
Transmission Line speakers steevo Planars & Exotics 2 26th March 2008 08:33 PM
Transmission Line speakers jjbmon Multi-Way 5 25th February 2008 03:03 AM
Transmission Line Speakers GeeVee Multi-Way 4 26th July 2007 01:24 PM
how to build a transmission line e-side Multi-Way 4 15th July 2005 08:24 PM
Transmission line speakers, sub, amp bbaker6212 Swap Meet 0 20th December 2002 08:29 PM
Copyright 1999-2017 diyAudio
