Old 22nd November 2008, 02:45 AM   #1
Default What tweeter above a Feastrex as mid?
I really liked the sound of a D5 Alinco Feastrex drivers I recently heard, so I bought a pair used. They were used full range in the system I heard.
Augmenting them on the low end with a 12" AE driver fed by a plate amp.
Would like to augment them at the high end too ... while they were amazingly pristine in the midrange and even lower treble, they were lacking in "sparkle" on the very top.
Will be using a DEQX as a three way crossover.
Suggestions for the high end? Figured I'd cross with a gentle slope somewhere between 5k and 10k based on how it sounds.
Will need 95+db efficiency above the crossover point.
Had thought of the Bemya TPL 150 or maybe a Fountek Pro 5i?
Old 22nd November 2008, 03:59 AM   #2
frugal-phile(tm)
planet10's Avatar
You'll want to use the best tweeter you can get your hands on... a raal or one of rhe big buck fostex horns (the horn wil probably have the advantage of better matching of dispersion at the XO.
Is a plate amp really gonna be good enuff?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd November 2008, 12:02 PM   #3
The plate amp (and the woofer) will only be handling from around 100 to 150hz on downwards, so it's not right in the heart of the midrange.
If it's not ok I will go with a higher quality outboard amp.
Can you point me to an appropriate Fostex horn link?
Old 22nd November 2008, 12:30 PM   #4
Default Something like this?
http://www.fostexinternational.com/c...ews_speak_head
if i only had the money ;-)
Old 22nd November 2008, 03:28 PM   #5
el`Ol is offline el`Ol  Germany
Meanwhile the Beyma TPL is also available in horn.
Old 22nd November 2008, 06:27 PM   #6
Pano is offline Pano  United States
Pano's Avatar
I agree with Dave, you're gonna want a top end tweeter. The Feastrex are so darn good, you'll notice anything less.
Take the Speaker Voltage Test!
Old 23rd November 2008, 06:55 AM   #7
cdwitmer's Avatar
I'm hardly an authority on such matters, but I think you should try to choose a supertweeter that is a point source rather than a line source. A ribbon tweeter would be a line source and the SPL will fall off 3dB with every doubling of distance. The point source Feastrex drivers will be falling off 6dB with every doubling of distance.
I would also suggest that, if there any worth considering available, you try to find a supertweeter made from paper. I think that may be a better match with the paper Feastrex drivers than metal would be.
Finally, you want to have something that you can cross very high but which also is capable of producing decent sound several octaves below the crossover point. Perhaps in your case this does not apply since you are going to be using a digital crossover and usually they are capable of very steep crossover slopes. I'm not a tweeter user at all so I don't get into this, but I know there are some who will insist the simplest passive crossover, with a very shallow slope, is the best for this kind of situation. I guess you will have to let your ears be your guide.
Unfortunately I'm not in a position to make a recommendation of a particular supertweeter, but it occurs to me that if there is one along the lines I'm describing, perhaps it is not inordinately expensive.
-- Chris
"Avoiding deportation from Japan for over a quarter century!"
Old 23rd November 2008, 04:02 PM   #8
cdwitmer's Avatar
Here is one paper tweeter, about which I know nothing:
http://www.sequerra.com/electronics/data/met7.html
Also, if I recall correctly, KLH had some 2.25-inch paper tweeters (alnico) that might be interesting to try.
-- Chris
Old 23rd November 2008, 06:10 PM   #9
frugal-phile(tm)
planet10's Avatar
... .sequerra.
The Sequerra tweeter is a modified peerless... starting with an old alnico one would probably be better. If you could find a set of the old 2"Isophon open-back alnico it is even better. But i doubt either of these has any hop of keeping up with the Festrex.
Using a set of $10 tweeters seems just a bit out of balance.
dave
Old 23rd November 2008, 06:46 PM   #10
At this point strong contenders would be a Visaton
http://www.visaton.com/en/high_end/ht_horn/tl16h_8.html
Or a Fostex:
Also reconsidering the plate amp ... it's supposed to be terrific, but I suspect I'd rather not take the chance in case it's not.
Planning to build it with a passive outboard crossover, and wire it so that I can actively amp all three drivers via the DEQX
Feastrex Fun Nelson Pass Full Range 234 3rd June 2009 05:25 PM
what amp and enclosure do you use for feastrex d 5nf? milen007 Full Range 2 27th April 2009 01:56 AM
Feastrex D5nf talawalla Vendor's Bazaar 1 11th February 2007 04:06 AM
Page generated in 0.10463 seconds (80.99% PHP - 19.01% MySQL) with 10 queries
