I would like to build a set of compact club-type party speakers. Something along the lines of an EAW JF60z or JBL Control. Internal volume in the 11-12 liter range and using a 130mm woofer. I won't be using them with a subwoofer all the time so I would like to get some impression of bass from them but it can cut-off fairly high to keep efficiency up. I am thinking a vent tuning around 75Hz. So, where to start? Can anyone point me in the direction of a similar project or make driver recommendations?
#2 |
The QB5 II reflex alignments give maximum output as they allow simultaneous maximisation of both voice coil dissipation and cone excursion, details here..
http://sound.westhost.com/qb5align.htm The auxiliary filter found in 5.1 systems can be used when using a subwoofer, if used with no filter at all the alignment has a punch region peak that is good for giving the impression of bass. rcw. |
#3 |
The B&C 8ndl51 woofer seems like the perfect choice for your given size. Efficiency and power handling are very high at 93.5db and when tuned to 70hz in 12 liters yields and f3 around 63hz or so. 200 watts yields average output around 114db with below tuning excurion reaching xmax around 56hz...lending toward an 80hz xover with a steep filter. I'm working on a pair myself with a vifa dx25 dome tweeter in a modified 6.5 inch waveguide to achieve my 1.4khz xover goal.
#4 | |
#5 | |
#6 |
Still working with them...but getting closer. Trying to get the Bass alignment right first with different volume/tuning. Try USSPEAKER.Com for the complete B&C line. The Neo drivers are all really well designed.
#7 |
Thank you for the lead.
Does anyone else have any ideas for a speaker like this? |
| Possible to design a high-power class D amp with a low output impedance? | 454Casull | Class D | 2 | 23rd February 2009 07:33 PM |
| High output chip design | G.L. Tirebiter | Chip Amps | 1 | 13th December 2005 04:39 PM |
| Good high output class D design with available PCBs... | wigginjs | Class D | 5 | 13th September 2004 11:02 PM |
| Page generated in 0.09107 seconds (75.11% PHP - 24.89% MySQL) with 10 queries |
