choosing specs for driver that will be used for OB
Old 20th November 2008, 06:49 AM   #1
c3conv is offline c3conv  Philippines
Default choosing specs for driver that will be used for OB
is there such a thing as right specs for bass driver in an OB application?
Old 20th November 2008, 05:56 PM   #2
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
My personal list:
Sd and Xmax should be as big as you can afford (money- and WAF-wise). Next on the list is Qts, where every expert is pointing in another direction:
Linkwitz prefers low Qts, Kreskovsky something in the middle and King rather high Qts. Prior to other T/S parameters I would have a look at noise free operation at Xmax. Some drivers are quite noisy (chuffing pole vent, ringing basket) to their back side, which does not show in CB, but can be annoying in dipole operation.
www.dipolplus.de
Old 21st November 2008, 02:09 AM   #3
PeteMcK is offline PeteMcK
Re:'Linkwitz prefers low Qts, Kreskovsky something in the middle and King rather high Qts' - that's because they all use different eq methods, Linkwitz fully active, Martin King fully passive...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 21st November 2008, 08:28 AM   #4
Drew Eckhardt is offline Drew Eckhardt  United States
Default Re: choosing specs for driver that will be used for OB
Noise coming off the back side (like a vented pole piece) is important but missing from commercial spec sheets.
choosing specs for driver that will be used for OBHide this!Advertise here!
Need help choosing a driver and a horn design. italynstylion Full Range 27 10th February 2009 01:28 AM
Need help with choosing speaker driver for bookshelf project sumacSK Multi-Way 1 11th February 2007 05:54 PM
Help choosing midrange driver Kittle Multi-Way 17 14th October 2004 08:21 PM
Choosing a sub driver based on T/S... manxam Multi-Way 2 21st February 2004 11:16 AM
Any specs on this JBL driver? Bull Car Audio 4 19th September 2003 09:21 PM
