Looking for best 10" woofer to be used to aid a "full renge" driver with some 92dB sesitivity.
The driver would be low passed initialy with first order so I'm looking for something well behaved at crossing point, aprox 120Hz.
Aligment will be TL or BR
Paper cone preffered and budget around $120 - 150 each.
Any suggestions?
Any suggestions?
10" high efficiency drivers...
If you haven't seen them yet you might take a look at the drivers from eminence. From a brief perusal it looks like everything they make is more efficient than 92db, some much higher. They have drivers w/paper cones from 8 to 18" and the guys at adire audio have them as well as parts express.
Good luck
Good luck
