How to use Martin J. King's software to design a TL loudspeaker?
Old 9th April 2003, 09:05 PM   #51
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by Bricolo
so, what are you calling a classical approach?
The Short Version. Then follow the link to the more detailed approach. I do not recommend building a line using this methodology... althou if you are looking to tune the line for flattest impedance Jon has some useful info.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th April 2003, 12:35 PM   #52
Bricolo is offline Bricolo  France
Bricolo's Avatar
dave
IMO, this is the complicated approach
Dave, I think you can explain me:
In Augspourger's tables, what does the Qts mean? Is this the Qts of your driver, or the pipe's one?
Old 10th April 2003, 05:41 PM   #53
frugal-phile(tm)
planet10's Avatar
dave
Old 10th April 2003, 07:18 PM   #54
Bricolo's Avatar
dave
some things made me thinks it's the TL's Qts
cf pages 8&9 from augspurger's paper
Old 11th April 2003, 03:14 AM   #55
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Default I like Martin's tl worksheets but . . .
I could never understand why every driver I found to input into the open end tl file always works best, for low-end output, with a very large starting line. Atleast 3 times the Sd of the driver just like Martin's Focal that the file already has inputted in it. Any body else experience this?
Old 12th April 2003, 04:12 PM   #56
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Default Pipe Size
The old wives tales of pipe with starting cross=sections of 1.5-2 Sd just won't die. I always start a simulation session with MJK's worksheets with So=4*Sd. Occasionally a pipe will work with 3*Sd, but not often.
Augspurger's tables really only work with large drivers with low Fs. Remember that Augspurger's method assumes Fp>Fs. So, if you start with a driver Fs=45, you are going to have a Fp and F3>50Hz. By using the mass-loading concept, you can design witn Fp<Fs. For exmple, my "Peerless Pipe" has F3=38Hz, even though the driver Fs=56Hz!
(However, if you do have a large, low driver and can stand a refrigerator sized cabinet, Augspurger's method can lead to a really impressive speaker. Of course, you can always get finer detail with MJK's worksheets.)
Bottom line: Unless you are using at least a 10" driver with Fs<30Hz, forget Augspurger, and please, let's never again mention the "classical method".
Bob
How to use Martin J. King's software to design a TL loudspeaker?Hide this!Advertise here!
martin j king's sheets bigcatdairy Multi-Way 8 31st October 2008 09:19 AM
help designing an martin king TL matjans Multi-Way 7 17th November 2003 02:11 PM
loudspeaker measuring/design software Jean Multi-Way 11 20th November 2002 05:51 AM
Martin King's Lowthers planet10 Multi-Way 13 14th November 2002 11:19 AM
Copyright ©1999-2017 diyAudio
