How to use Martin J. King's software to design a TL loudspeaker? - Page 3 - diyAudio
Old 6th April 2003, 06:04 PM   #21
Bricolo is offline Bricolo  France
Bricolo's Avatar
OK, now I see what you are meaning!
You think that the back opening on my drawing is a port (I mean a round port, like on a bass reflex)
But, in fact, it's still the TL itself, the opening of the TL. You can consider it as a second fold
Do you see how the thor is build? my project is the same, the opening isn't a round port, but a rectangular opening. The back plate is simply shorter that the speaker's height
The opening height is the same as 1/5 the speaker's deepht
Old 6th April 2003, 06:06 PM   #22
Bricolo's Avatar
another question: in TQWT, epsilon is the ratio between driver placement and line lenght
in offset driver, it's in in.L^-1
how do I use it? is it the number of inches it is far from the closed output? so not a ratio?
Old 6th April 2003, 07:46 PM   #23
MJK is offline MJK  United States
Epsilon is always a dimensionless ratio of driver position. In ML TQWT I input 0.5 because the driver is at half the length. In off-set driver I calculated epsilon by dividing the driver position by the length.
epsilon = driver position / L
epsilon = 6 inches / L = 6 inches x L^-1
There are advantages to both ways of expressing this ratio.
So in your "Thor" clone I would model the line up to midheight of the opening in the back then add a short section to get to the box inside edge and then on last section with an area equal to the opening and a length equal to the wall thickness. I think I did some thing similar for my first TL built with the Focal drivers. Take a look at the pictures in those articles.
Hope that helps,
Old 6th April 2003, 08:42 PM   #24
Bricolo's Avatar
can you draw it, please?
Old 6th April 2003, 11:36 PM   #25
Take a look at Figure 35 in my Focal TL articles. You need to draw a picture like this except point 6 should be at the outer edge of the cabinet opening (outer most dashed line in the figure). This is the situation you want to model.
Hope that helps,
Old 7th April 2003, 07:22 AM   #26
Bricolo's Avatar
Hope that helps,
that's the way I want to go
except that the line will be tapered (the inner bafle won't be at 90)
Old 7th April 2003, 11:05 AM   #27
So all you have to do is change the values of the areas. If you are using the offset driver or ML TQWT worksheet this is only a couple of entries. If you are using the TL Sections worksheet then you can put in areas at discrete positions along the line. I think that the TL Sections worksheet is already set-up for the Focal TL geometry shown in the figure.
Old 7th April 2003, 07:25 PM   #28
Bricolo's Avatar
what is the TL sections worksheet used for?
I haven't understood it's role
Old 7th April 2003, 07:41 PM   #29
The TL Sections worksheet is totally general without any "user interface" for easy input of a design geometry like the Offset Driver or ML TQWT worksheets. You have to go in and enter each section geometry by hand. It was my initial model until people started asking for simple input of certain geometries.
It is the basis for all of the other worksheets, the calculations are the same. The other worksheets fill in the individual geometries from the general simple input area on the first page. In the TL Sections worksheet you can model any geometry (folds, restrictions, sudden changes in cross-section or stuffing density, ...) that you can sketch out. It just takes time to enter all of the data for each section by hand.
That is the only difference, it is totally user input dependent.
Old 7th April 2003, 07:45 PM   #30
Bricolo's Avatar
how do you add a fold?
martin j king's sheets bigcatdairy Multi-Way 8 31st October 2008 09:19 AM
help designing an martin king TL matjans Multi-Way 7 17th November 2003 02:11 PM
loudspeaker measuring/design software Jean Multi-Way 11 20th November 2002 05:51 AM
Martin King's Lowthers planet10 Multi-Way 13 14th November 2002 11:19 AM
Copyright 1999-2017 diyAudio
