Old 13th November 2008, 09:22 PM   #1
grimberg's Avatar
Default Design suggestions using 6.5” Peerless NPT-11-078-1
During BAF 2008 Jack Hidley generously handed out some 6.5” Peerless NPT-11-078-1 drivers, the subwoofer used in the NHT Super Two and Super Sub loudspeakers. I brought some home with me and would like to use them in a project. I am asking for design ideas and am sure other people will be interested as several attendees took home the same driver.
On Jack Hidley’s personal page at http://home.comcast.net/~jhidley/ there is a link to an Excel spreadsheet containing T/S parameters and related information for this and other drivers. Here is what it says about the NPT-11-078-1.
Part # : npt-11-078-1
Used in NHT models : Super Sub Super 2
Brand : Peerless
Shielded : No
Basket : Steel
Cone material : Laminated poly
Re (Ohms) : 4.84
Fs (Hz) : 51.7
Qms : 2.738
Qes: 0.584
Qts: 0.481
Vas (l): 16.10
Cms (m/N): 0.000543
Mms (g): 17.4
Diameter (mm): 136
BL (N/A): 6.85
SPL (2.83V): 87.64
Zmax (Ohms): 27.6
Sd (m^2): 0.01453
Xmax (mm): 4.9
Hg (mm): 6.0
Hvc (mm): 15.7
Former material : Aluminum
# of coil layers : 2
Coil diameter (mm) : 32
Old 13th November 2008, 09:24 PM   #2
grimberg's Avatar
One idea could be a design similar to what Jack demonstrated at the event, using six Peerless woofers, a midrange and a tweeter in a sealed cabinet built out of concrete form.
You can see them in the last picture posted by Wavebourn at:
http://www.diyaudio.com/forums/showt...14#post1636814
Old 13th November 2008, 10:39 PM   #3
willick is offline willick  Canada
willick's Avatar
Grimberg,
You didn't happen to grab enough of these drivers that you could spare a pair did you? I need 2 to repair my actual SuperTwos. Do you have a friend that might have?
Thanks in advance...
-John
see the thread I pathetically started here: Burning Amp - free NHT woofers..?
"Any smoothly functioning technology will have the appearance of magic."
Old 14th November 2008, 12:51 AM   #4
they look good down to the low 40s in 30L tuned to 43Hz, down to low 30s -3dB EBS in 40L tuned to 33Hz, double volumes for 2 drivers...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 16th November 2008, 10:45 PM   #5
grimberg's Avatar
Could you tell me what modeling software you use?
Old 17th November 2008, 02:55 AM   #6
GM is offline GM  United States
GM's Avatar
If you want to wow your friends with big SPL down well below Fs from a little driver, a tapped horn will do it if you don't mind a big cab.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th November 2008, 03:50 AM   #7
grimberg's Avatar
GM
I would like to try it. Where can I find more information?
Old 17th November 2008, 03:36 PM   #8
GM's Avatar
This long thread has the vast majority of TH knowledge along with many designs and simming programs info and I recommend you browse it all if you're truly interested in designing your own and DLing Hornresp if you have a Windoze machine to work through permutations of existing designs using your driver's specs to find what you consider the best trade-off between gain BW and size.
GM
Old 28th November 2008, 06:31 AM   #9
Andersonix's Avatar
Can anyone point us toward a frequency response curve for these NPT-11-078-1 Peerless drivers (Peerless model 850397)? I'd like to know what low-passing at about 4200Hz would look like.
Peerless 830656 suggestions giralfino Multi-Way 34 31st October 2011 09:21 AM
enclosure suggestions for peerless driver BWRX Subwoofers 13 18th November 2008 03:00 AM
Anyone looking for Peerless HDS 2-way design? Jay_WJ Multi-Way 6 7th October 2007 04:31 AM
Suggestions for 4th order bandpass, Peerless cones MASS Multi-Way 0 22nd May 2003 10:00 AM
Page generated in 0.09444 seconds (77.69% PHP - 22.31% MySQL) with 10 queries
