the idea of building a high efficiency 3 way keeps pooping in my head.
it would be good if it were around 96db or greater. i have a 6watt SEP amp i like. i'd probably keep the crossover first order. what software (freeware perhaps) can i use to model frequency response? i was thinking about using a Fountek Neo 3cd, Audax PR170mo, and for the woofer, which is hard. i was thinking about an Eminence CH2010 basslite http://www.parts-express.com/pe/psho...16&ctab=1#Tabs any ideas with that one? i'd consider a dome tweeter if i could find one efficient enough. as far as response should the tweeter be a little lower than the mid? so maybe have the mid around 96db and use a tweeter around 94db? thanks and sorry if these are newb questions. |
#2 |
Wow, first order with the Fountek? Seems difficult to my eyes......
Also the audax looks "problematic" with first order imo. But I love first order a la thiel to say, I prefer sacrifice a bit of efficency and go 6dB when possible :-) The peerless hds dome is about 93-94 dB and it is 8 ohm if I well remember. Cheers, Paolo |
#3 |
i was thinking the low pass on the audax might be hard.
also, i remembered i have a GR research (gr-t6 i think it is) dome tweeter that is 6 ohm and 96db sensitive.... i figured the fountek would cross at about 4.5k or 5k. (madisound says 2nd order at 2500hz is good). audax maybe 700hz to 2.5k the ch2010 have a high pass around 250hz or 300 hz. if i can't keep the design sensitive there is not much point in doing it. also, i dont' have the equipment to take my own measurements so i need to model this stuff with software. another question. how much sensitivity would i lose by going 2nd order on the mid and tweeter? |
#4 | |
Maybe do you mean the H/P of the audax....it has very low Xmax. You'll lose nothing exerpt transient perfection Cheers, Paolo |
#5 |
yeah sorry, h/p of the audax is what i meant to say.
#6 |
How about a two way with a fullrange driver like fostex fe126e and a 15" instead of the 10"?
Simpler to get right without measuring, and gets you more low freq extension.
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor... |
#7 |
i thought about a full range with a sub for a low end ext.
i have some 2 way now that use an eminence alpha 8" with a vifa tweeter in a bass reflex box. sensitivity is just enough. i'd kinda like a little more midrange detail, a little more sensitivity and also a bit more low end extension... how do the full range drivers sound? i'll have to do some searching as i haven't really looked into them much at all. |
#8 |
I'll point you to a couple threads people are doing for high efficiency 3ways right now.
This is a 3way using the TD12S and neo pro5i http://www.avsforum.com/avs-vb/showthread.php?t=1035126 using TD12S, phl mid and neopro5i http://www.avsforum.com/avs-vb/showthread.php?t=1061558 The Basslines by dlneubec. These were inspired by the salk system below. He did quite a bit of waveguide experimentation to get the dome tweeter efficiency up. http://www.htguide.com/forum/showthread.php4?t=29988 The salk system that inspired the one by dlneubec. http://www.audiocircle.com/circles/i...?topic=54161.0 John |
#9 |
thanks john, i'll look at those when i have some time.
#10 |
http://www.troelsgravesen.dk/JA8008_DTQWT.htm
I can't wait for an excuse to give these a go. One day... |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Low wattage, high efficiency, high quality? | Nordic | Multi-Way | 5 | 4th September 2005 11:12 PM |
| High Efficiency, High Power Handling? | Bogie | Multi-Way | 3 | 2nd July 2005 05:49 AM |
| Suggestions for high efficiency high SPL kit/design | Kanga | Multi-Way | 50 | 23rd May 2003 12:52 AM |
| High Efficiency Speakers | markkanof | Multi-Way | 17 | 9th January 2002 06:00 AM |
| Page generated in 0.12500 seconds (79.95% PHP - 20.05% MySQL) with 10 queries |
