I am trying to decide what resistors to use for my crossover. Does the wattage of the resistors matter? One of the resistors is 3.3 ohm and one is 8 ohm. Could I use this one
http://www.amazon.com/3-0-Ohm-Flamep...933673&sr=1-21 and this one http://www.amazon.com/8-2-Ohm-Flamep...6259016&sr=1-2 for the speaker on top of this page? http://www.apexjr.com/speakerstuff.html |
#2 |
Speakerholic
Those are not for XO's You can use these types http://www.parts-express.com/non-ind...stor-index.cfm The Dayton's for shunt work, the mills for your signal path. |
| simplest three way crossover using 2 caps and 1 resistor | DanDini | Multi-Way | 1 | 1st September 2008 09:33 PM |
| dynaudio crossover - value of tweeter resistor? | adamt | Multi-Way | 3 | 23rd January 2007 10:49 PM |
| electronic crossover cap resistor ratio | ostie01 | Multi-Way | 9 | 17th February 2006 12:57 PM |
| Active crossover resistor/cap size | paulhfx | Multi-Way | 3 | 22nd May 2005 02:38 PM |
| crossover resistor | sma | Multi-Way | 2 | 11th October 2004 03:59 PM |
| Page generated in 0.05854 seconds (74.74% PHP - 25.26% MySQL) with 10 queries |
