Old 9th November 2008, 08:18 AM   #1
Thims is offline Thims  Australia
Default Active cinema speakers
Hello all,
I am planning a cinema with an 2.35 acoustically transparent screen.
The room is 4.3m wide, 7m deep and 3m high, sitting position about 3.5-4m.
I am wanting to build 3 main active speakers behind the screen and active rears.
I am after something comparable or better than the Genelec AOW312 or the HT315.
My ideas are revolving around the PHL 4530 12" woofer, PHL 1220 or 1520 mid and Illuminator (D3004/6620000) tweeter for better off axis.
I have also considered using the Illuminator 15WU/8741T00.
Electronics and amplification mostly by Ground Sound.
The rears i am still working out which would be best, direct or diffuse.
Would this combination work? Or what other suggestions could you make that will work.
Thanks again
Old 9th November 2008, 08:31 AM   #2
Lindell is offline Lindell  Sweden
The PHL 12" you should use is the 4021 (I love the sound of it). not the 4530. The 4021 is alot better in lower register.
Ground Sound rocks.
Active Crossover and 7.1 Home Cinema Amp mikethomas79 Multi-Way 4 28th February 2008 01:53 PM
home cinema speakers skogs Multi-Way 6 7th September 2007 05:15 PM
Help needed in making cinema speakers!!! noob! lions_gym Multi-Way 18 23rd May 2007 07:57 AM
Home cinema front speakers/subwoofers mcai7et2 Multi-Way 0 31st January 2003 10:53 AM
TV/home cinema speakers Hay Introductions 1 6th January 2002 04:50 PM
Page generated in 0.06694 seconds (67.57% PHP - 32.43% MySQL) with 10 queries
