As long as the line is stuffed, the resonances along the length of the line should be attenuated significantly due to the high particle velocity at the open end of the tube...but what about the resonances that propagate along the radii?
Is there anyway to deal with the radial resonances other than building appropriately sized diffusors in the interior? Wouldn't the particle velocity be 0 at the walls and the pressure be at maximum, thus negating any absorptive effects of foam for radial modal resonances.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#2 |
frugal-phile(tm)
I stuff a midrange line "backwards"... heaby at the terminus getting lighter as you approach the driver. Get it right and you have an aperiodic line (or near to it) with little or no resonant structure.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
How does this effect the radial modes? Varying the density of stuffing along the length of the line would intuitively only effect those modes who propagate down the length, not the radial modes.
#4 |
What radial modes? If the TL is a round pipe there will be an infinite number of standing waves, but all at theoretically the same frequency that the stuffing will attenuate.
If you're referring to the pipe's physical vibration modes, obviously it must be rigid/damped enough for them to either be below or above its pass-band, so normally it would be 'U' clamped (mass loaded) to the back of the baffle. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 | |
#6 | |
frugal-phile(tm)
dave
#7 | |
#8 | |
frugal-phile(tm)
1/ what you do damping wise in any other box 2/ taper the line -- in both directions if you want to minmize side-to-side resonances. dave
#9 | |
2. Tapering the line merely redistributes the resonance modes and makes them simply harder to predict. If you tapered the walls of your listening room, would that get rid of your bass modes?
#10 | ||
frugal-phile(tm)
The TL itself concentrates the main modes into the length of the line. dave
| Placement of subwoofers along standing waves, exciting modal resonances | thadman | Subwoofers | 27 | 14th December 2008 12:36 PM |
| Does furniture obstruct modal resonances? | thadman | Multi-Way | 2 | 2nd December 2008 06:05 AM |
| transmission lines | grahamfocal | Introductions | 12 | 15th January 2008 07:38 AM |
| Transmission lines | duderduderini | Multi-Way | 2 | 29th July 2007 11:56 AM |
| Page generated in 0.11713 seconds (82.57% PHP - 17.43% MySQL) with 10 queries |
