Old 4th November 2008, 02:53 PM   #1
Havenwood's Avatar
Send a message via MSN to Havenwood
Question Speaker Configuration
Hi, can comment anything about these speakers?
or
Why so many speakers?
Are multi-amp?
Is better than a 3-way?
Greetings
- Music by John Williams -
Old 4th November 2008, 03:05 PM   #2
Speakerholic
Cal Weldon's Avatar
They are called line arrays. Dr Jim Griffin wrote a paper on them. Unfortunately it's too big to attach so you'll have to google it for a better explanation
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th November 2008, 03:10 PM   #3
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Yeah the line Array........Very impressive to show off, somewhat easy to build. Notice the curvature of the 'Top' one, as if to focus the beaming effects of the drivers onto one point. As if in a parabola. No no, not the porabola
The imaging is quite good...sometimes the array will be supplimented with a subwoofer as the "fullrangers will not have any bottom end.
Look up some of the old Infinity Arrays. Bobby Shred stuff.
____________________________________Rick.......... .
Old 4th November 2008, 03:20 PM   #4
Havenwood's Avatar
Ok. thanks!
But they are multi amplified?
Each speaker has a specific filter?
Are really big!
I will look at google
Old 4th November 2008, 03:48 PM   #5
Speakerholic
Cal Weldon's Avatar
Line array just tells you there's a bunch of drivers in a line. It says nothing about the drivers, the number of them, the possible XO or power tapering or, or... It just means what it says. When you read the paper you will better understand the "whys" behind them. Some persons swear by them and others not so much. To each his own.
Old 4th November 2008, 03:59 PM   #6
Try www.partsexpress.com and look up the "project" speakers, find the line array with Thirty-two drivers per side!
_______________________________________Rick....... ..
Old 5th November 2008, 11:21 AM   #7
The fundamental problem is the transition from line dispersion to
the hemispherical tweeter output. They may look like line arrays
but not (due to filtering) operate as line arrays, all in the details.
If they are not line arrays they are not as cost effective as 3-ways.
If they are line arrays then there are myriad issues.
/sreten.
Old 1st April 2009, 02:26 PM   #8
The Gryphon poseidon is not a line array, its a 4 way D áppolito with active bass. Read the design story at www.gryphon-audio.com
Does anyone know the name of this configuration? wildswan Solid State 0 8th January 2009 11:25 PM
better amp configuration longthrow Solid State 35 22nd October 2007 10:43 PM
Is a bridge / parallel configuration of 3875 is better for my speaker ? 100db Chip Amps 7 8th March 2006 10:42 AM
Bipolar speaker configuration ... need info! accoustical pros and cons ? JinMTVT Multi-Way 36 30th July 2004 05:21 PM
odd configuration Patrat Multi-Way 0 4th February 2003 03:46 AM
Page generated in 0.09540 seconds (75.94% PHP - 24.06% MySQL) with 11 queries
