high im looking around for some cheap 2-3 inch inverted soft dome mids for a open baffle system and im wondering what you guys could suggest that is budget concious ($100-250 for a pair)
and has at least a 80 wrms power handleing and a freqency response from approx 800- 6000 hz |
#2 |
2" inverted soft dome ? I'm not aware of such a beast ..... I'm also no expert on Australian driver availability. THe Hi-Vi DMB-A seems good value, see tests at www.Zaphaudio.com . |
#3 |
Speakerholic
I've not seen a 2" inverted dome either FWIW.
#4 |
Me either, I don't think, for what little that's worth.
#5 |
Thiel/Accuton makes a 2" inverted dome...ofcourse its a hard dome and not soft
#6 |
Is this not a 2" inverted dome?:
http://www.swanspeaker.com/product/htm/view.asp?id=120 Hard cone either way... Morel MDM-55 is supposed to be quite good |
#7 |
which is used in Dr. Linkwitz's Pluto speakers. Not a "soft dome," but quite usable, and cheap too.
http://www.madisound.com/catalog/pro...oducts_id=8465 Kurt |
#8 |
sorry guys this is like the first time talking about speakers to other lovers of audio i ment that they are convex or dome out, concave is what i have for all other drivers (woofer subs and orginal mid)
thanks guys I was looking at some of the older Morel MDM 55 dome mids but they are expensive for this project |
#9 | |
thanks sreten, from tobe |
#10 |
is it true that a smaller diameter dome mid will do equal to or more frequency range as a big surface area cone such as the ones I'm currently using.
just verifiing that, ithink the morels will be a hit, a bit on money spending is in order guys |
| Sonance Soft Dome Tweeters | ejfud | Swap Meet | 5 | 2nd March 2011 11:57 PM |
| Inverted Mos HV soft start | richwalters | Tubes / Valves | 0 | 5th January 2009 07:28 AM |
| Inverted Dome vs Cone vs curvilinear??? | AAXenoStrange | Multi-Way | 0 | 24th June 2006 07:24 PM |
| Soft Dome 3" Midrange On E Bay | Jacques777 | Swap Meet | 0 | 14th June 2003 01:47 AM |
| Soft-dome midrange driver? | Test Pilot | Multi-Way | 18 | 22nd November 2002 11:41 PM |
| Page generated in 0.09533 seconds (82.52% PHP - 17.48% MySQL) with 10 queries |
