what 2' inverted soft dome, cheap
Old 4th November 2008, 02:09 PM   #1
robywan is offline robywan  Australia
Default what 2' inverted soft dome, cheap
high im looking around for some cheap 2-3 inch inverted soft dome mids for a open baffle system and im wondering what you guys could suggest that is budget concious ($100-250 for a pair)
and has at least a 80 wrms power handleing and a freqency response from approx 800- 6000 hz
Old 4th November 2008, 03:16 PM   #2
R.I.P.
2" inverted soft dome ? I'm not aware of such a beast .....
I'm also no expert on Australian driver availability.
THe Hi-Vi DMB-A seems good value, see tests at www.Zaphaudio.com .
/sreten.
Old 4th November 2008, 03:50 PM   #3
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I've not seen a 2" inverted dome either FWIW.
planet10 needs your help:
Let's help Ruth and Dave
Old 4th November 2008, 07:16 PM   #4
BHTX is offline BHTX  United States
BHTX's Avatar
Me either, I don't think, for what little that's worth.
Old 4th November 2008, 07:35 PM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Thiel/Accuton makes a 2" inverted dome...ofcourse its a hard dome and not soft there should be a new one with higher sensitivity and more wideband, but seen yet...theres also a 3", but not very wideband
sometimes we know very little, and sometimes we know too much
Old 4th November 2008, 08:24 PM   #6
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Is this not a 2" inverted dome?:
http://www.swanspeaker.com/product/htm/view.asp?id=120
Hard cone either way...
Morel MDM-55 is supposed to be quite good
Old 4th November 2008, 09:02 PM   #7
KCHANG is offline KCHANG  United States
Default or the Aura Sound NSW2-326-8A
which is used in Dr. Linkwitz's Pluto speakers. Not a "soft dome," but quite usable, and cheap too.
http://www.madisound.com/catalog/pro...oducts_id=8465
Kurt
Old 5th November 2008, 12:20 PM   #8
Default i was confused
sorry guys this is like the first time talking about speakers to other lovers of audio i ment that they are convex or dome out, concave is what i have for all other drivers (woofer subs and orginal mid)
thanks guys
I was looking at some of the older Morel MDM 55 dome mids but they are expensive for this project
Old 5th November 2008, 12:20 PM   #9
/sreten.
I looked on this site (zaphaudio), are these american prices, if so these are still very low, and i can see my eye on some of those drivers
thanks sreten, from tobe
Old 5th November 2008, 12:20 PM   #10
is it true that a smaller diameter dome mid will do equal to or more frequency range as a big surface area cone such as the ones I'm currently using.
just verifiing that, ithink the morels will be a hit, a bit on money spending is in order guys
what 2' inverted soft dome, cheapHide this!Advertise here!
Sonance Soft Dome Tweeters ejfud Swap Meet 5 2nd March 2011 11:57 PM
Inverted Mos HV soft start richwalters Tubes / Valves 0 5th January 2009 07:28 AM
Inverted Dome vs Cone vs curvilinear??? AAXenoStrange Multi-Way 0 24th June 2006 07:24 PM
Soft Dome 3" Midrange On E Bay Jacques777 Swap Meet 0 14th June 2003 01:47 AM
Soft-dome midrange driver? Test Pilot Multi-Way 18 22nd November 2002 11:41 PM
