Old 4th November 2008, 05:41 AM   #1
Default Interesting 'Labyrinth' paper
http://www.extra.research.philips.co...s/aar06pu3.pdf
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 4th November 2008, 06:36 AM   #2
Thanks Pete you can never go wrong adding to the sum of human knowledge (or at least making it more accesible) without reading it in detail it looks like he's given us the science behind Fris's DALINE from "Hi-Fi News Record Review" in the '70's. At least that is what the diagrams suggest at first glance. Ta
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 4th November 2008, 07:38 PM   #3
Default Some notes:
An interesting aspect of this paper is that they consider Fp can be lower than Fs.
Essentially, they use the pipe to create a hi-Q resonance and control it with a filter system (few details given though)
Their formula (5) gives a relationship for Sd which appears to contradict their claim that their method is useful in designimg ‘very compact loudspeaker systems’
Formula (2) might be useful if it’s practical application is made clearer.
They talk about an optimum value of BL, but I can’t see anywhere where they show how to find this, perhaps they’re making assumptions that are opaque to a layman such as myself;
They have a simple formula for end correction, I think Martin King has shown that it isn’t quite as simple as they think.
The ideas presented are interesting, but I suspect that too many assumptions are being made, perhaps someone with more familiarity with the maths/engineering involved can comment?
Old 4th November 2008, 10:34 PM   #4
frugal-phile(tm)
planet10's Avatar
Here is the original 1937 Onley paper they scooped some of the images from
http://homepage.mac.com/planet10/TLS...inth-Olney.pdf
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th November 2008, 01:35 AM   #5
Thanks p10, an interesting paper, although Olney's trying to achieve the opposite of the guys who wrote the paper above.
What I find interesting here is the possiblity of a TL equivalent to an EBS alignment (having a bunch of drivers that have too high an Fs ); probably not too hard to do ...???
Old 5th November 2008, 11:09 AM   #6
A paper on essentially how to make an an awful loudspeaker.
The jist is that it is high efficiency and has high output capability
at a particular frequency and the bass is bandpassed filtered to
concentrate at that frequency and further manipulated such
that its envelope follows the wider bass spectrum.
In other words high efficiency garbage, the details do not matter ....
/sreten.
Old 6th November 2008, 04:52 AM   #7
Cloth Ears's Avatar
Dave, thanks for the Olney reference - saved me heaps of looking.
The other (AES) paper looks like something Bose will come hunting Messrs Aarts, Nieuwendijk and Ouweltjes about. Seems to be treading on Bose' area of 'expertise'...
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
True labyrinth versus infinite baffle Tubamark Subwoofers 2 27th April 2008 02:06 AM
interesting amp & interesting problem m6tt Tubes / Valves 9 14th August 2007 06:28 PM
This paper...anyone? mikeks Solid State 6 18th January 2005 05:12 PM
amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? siu sin man tho Digital Source 0 17th March 2004 12:31 PM
A Corner Labyrinth Transducer bbaker6212 Multi-Way 2 16th August 2002 04:30 AM
Page generated in 0.08804 seconds (76.07% PHP - 23.93% MySQL) with 10 queries
