Right now the closest contender is the Peerless 811647 HDT 100 horn loaded dome tweeter. http://www.d-s-t.com.au/data/Peerless/811647.pdf
It is a good product for the low price, but it may or may not break if the DIY party speakers were played to 120Db, which corresponds to 100W system power. This is the maximum rated power for the Peerless, which is basically a tricked up hi-fi dome tweeter. How do ordinary dome tweeters hold up near maximum rated continuous system power? The plus for the Peerless is that it is an established brand so it cant sound bad (if not good), and soft dome tweeters have smoother response and inoffensive (im guessing). At least compared to a cheap no name titanium compression driver at the electronics shop. Any other solutions I may not have thought yet (DIY or ready made)? |
#2 |
Providing you've got clean power up to and beyond 100W, so your not ever feeding a clipped signal, then it should be fine. The crossover will limit the power effectively going to the tweeter, where the woofer may be using 100W the content above 2.5khz may only require an average of 10W-20W, peaks may be of 100W but these arn't an issue here
The baffle step will also make the tweeter louder than the woofers in effect, by 6db, then the tweter requires only 1/4 of the power because of this alone. Unless your woofer is 106db efficient and you won't be using a pad on the tweeter? |
#3 |
120 dB from a tweeter ? - ouch!
Maybe take a look at horns / compression drivers. Rob. |
#4 |
Surely not wanting 120dB of treble power!? I presumed the question meant an SPL of 120db overall and would the tweeter cope in such an application which I believe it would. 120dB of treble, ouch indeed
#5 | ||
Im not sure if you are aware, but the 100W rating already takes assumes the tweeter is crossovered. The tweeter is probably 15-20W by itself. Is it still fine? Has anyone run 100W through their 2 way hi-fi systems and not a hitch? Quote:
#6 |
Hi ,
I am not sure for the 120 dB, it is really a dangerous level Anyway have you thinked to HI-VI RT2 PRO ( planar)? Cheers,, Paolo |
#7 |
With the existence of compression drivers, it'd be absolutely ridiculous to even consider "hi-fi" tweeters for this design IMO. You probably think they don't sound as good because you've never heard one implemented correctly. Most diffraction horns sound awful IMO, and this is pretty much always how they're used in high output professional loudspeaker systems. If used correctly in a design for personal use, they can easily beat the pants off any little inefficient tweeter toys out there in every aspect. Whenever you're interested in coming up with any loudspeaker system.. instead of using a compression driver because you think you have to, try to base the design on the fact that you WILL use a compression driver, always. It works!.. IF done correctly, which is extremely critical.
#8 |
Paolo, how does that Hi-Vi RT2 sound? Could you compare it with a Fountek Pro5i?
#9 |
I'm sorry ,I have not tried it. Just read the Hi-vi datasheet and simulated in my x-over simulator.
From the data looks interesting IMO and good price Cheers, Paolo |
#10 |
THe old Motorola KSN 1177 was a dual piezo element design I used to use. It was 100 db per watt.
Mark
Mark |
| 2 or 3 cheap ways 1 Proyect for the PC? | samsagaz | Multi-Way | 46 | 25th March 2007 04:17 PM |
| Tweeter for 1.5kHz | audiobomber | Multi-Way | 8 | 12th May 2005 03:38 PM |
| SS97's at 1.5Khz | 5th element | Multi-Way | 5 | 19th February 2004 04:22 PM |
| Ways to make a cheap computer sub less boomy? | downhere | Subwoofers | 3 | 11th November 2001 06:25 AM |
| Page generated in 0.10873 seconds (78.00% PHP - 22.00% MySQL) with 11 queries |
