Old 1st November 2008, 10:34 AM   #1
otto88 is offline otto88
otto88's Avatar
Default Baffle profile – baffle edge problems?
Attached is a draft version about 4 profile for an open baffle design, zipped Excel with a grid to a scale. (If you have problems seeing it, save it then open with Win Zip, extract & open with Excel). It'll be on castors to move easily.
The baffle size and shape is to accommodate several drivers I have, acting as a comparator/ test bed.
Particularly because its large - 2.1 m or 7 feet high – and in an attractive shared room, good looks are important. A large slab of rectangular baffle is not an option. The profile stepping in towards the top, looks like a well known NYC Art Deco building that both my wife and I like.
I know a large roundover is desirable for reducing baffle step, but is the number of corners on the edges a problem?
If it is, I could use transparent extensions of Perspex or similar (as nuuk has done), to smooth the outer shape to similar to one of these
http://www.hawthorneaudio.com/forums...9b2389e#p32865 About three posts below that, is a pic of a wood baffle made in the lower design shape.
That's the inspiration for the curved lines extending out from near the top in my drawing.
Is a curved baffle better than a staggered one?
Cheers
Old 1st November 2008, 04:25 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
IMO, when you get into this realm of decorative "art", baffle step should be the least of your worries. How are you gonna cut glass for all those little windows - that is what you should worry about, and where are you gonna get thin stone veneer?
You could try placing some absorptive foam or felt on the top of the steps, and say it is there to simulate roofing or to protect people from sharp corners, or to keep your wife from putting plants on them
If you put the acrylic arches on there, people will REALLY think you are nuts.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
Old 1st November 2008, 04:46 PM   #3
otto88's Avatar
Ron,
It would be custom cut, with say three steps.
> stone?
The Cramps’ tombstone inspired look ~ didn’t last long.
Or a Fay Wray/ Nicole Kidman dancing on the spire.
> acrylic arches
Nuuk has done it, it looks ok.
Seriously, will The Edge simulate that shape well, for an open baffle?
Old 2nd November 2008, 11:06 PM   #4
otto88's Avatar
The art deco profile in timber is for looks.
The added single curve per side in a transparent material is to smooth the baffle shape, without adding to apparent bulk, and make the baffle wider for more extended midbass.
Also “stepping out” the width at the bottom to about 500 mm = 20”, allows 18” drivers, a good size for dipoles.
Cheers
Old 3rd November 2008, 09:56 AM   #5
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Otto88,
its VERY unusual to present baffle designs in EXCEL spreadsheets. To me your Art Deco tower looks like this:
I really can´t see were any drivers of what size are going to be on your baffle. Without that information it is almost useless to comment.
Some first impressions:
Even without the acrylic extensions I don´t see any problem with those edges.
You don´t need the extensions reaching to the top of the tower. If they stop at 1 m that would be more than sufficient.
Normally a tweeter would be positioned at ~ 1 m height. At that level the baffle should not be almost 1 m wide.
Confused
Rudolf
www.dipolplus.de
Old 5th November 2008, 01:17 AM   #6
otto88's Avatar
Hi Rudolf,
I know, but at this stage that's the only way I know; how did you turn Excel into a normal image, able to be posted?
I was trying to focus just on the profile . .
> Even without the acrylic extensions I dont see any problem with those edges
That's what I wanted to know.
> You dont need the extensions reaching to the top of the tower. If they stop at 1 m that would be more than sufficient.
The idea of them running to the top is that’s where the multiple steps are. So each corner * doesn’t add another "diffraction point"?
Yes in this design some are, some are above that, so those above that height will suffer some rolloff, above Hz of? Mmm.
It’s to be a comparator/ plug and play/ test bed – hence eg multiple tweeters etc
As you said it was hard to comment without drivers . .
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 23 12th February 2013 02:23 AM
Dumb question about Edge Baffle Designer Aengus Everything Else 2 4th February 2009 08:07 PM
Baffle edge - ideal curvature? Tenson Multi-Way 19 1st June 2008 10:55 PM
New version of The Edge baffle step simulator Svante Multi-Way 13 8th December 2004 10:16 AM
The Edge simulates the baffle step. Svante Multi-Way 0 30th March 2004 12:33 PM
Copyright ©1999-2017 diyAudio
