Old 31st October 2008, 08:18 PM   #1
Default Fiberglass stuffing and vented magnets
anyone ever have trouble with stuffing enclosures with drivers having vented magnets?
ie. voice coils rubbing from ingestion of particles?
or is this an urban myth?
I've got 9 ft^3 to stuff, twice, and have access to free fiberglass...
Old 31st October 2008, 08:50 PM   #2
Andersonix's Avatar
No, but I have seen speakers that used fiberglass inside a cloth bag, presumably to cut down on the dust (and it makes for a tidy assembly, as you can staple the bag to the inside wall).
But I have also built speaker boxes with fiberglass without problems (except for a little itching). It would take a lot of fiberglass dust to interfere with a voice coil....
Old 31st October 2008, 11:26 PM   #3
Acoustic research used to put a sheet of very porous creped paper behind their woofers in their boxes stuffed with FG. It was cut in a sheet large enough to fill in completely behind the woofer hole.
The paper was called Kimpak (now Versa-Pak) sold by Uline.com.
The Kimpak served 2 purposes. It kept clumps of FG out from behind the woofer cone and also helped filter fine bits of broken FG from getting into the VC thru the spider.
Old 1st November 2008, 05:20 PM   #4
Speakerholic
Cal Weldon's Avatar
Old pillow slips work well to contain fiberglass.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd November 2008, 02:07 AM   #5
Default Here's a pic of the WMTMW
it's a sandwich of 1/2" mdf and 5 ply 15/32" ACX arauco plywood
still have to do some bracing.
Old 13th November 2008, 03:53 PM   #6
Default poylyurethane finish
if i sand the plywood to a 800 grit smoothness, what type of finish would you recommend (and how much, ie. gallons?) they're 6 ft by 18" all sides
fiberglass TL sergiof Multi-Way 44 4th October 2009 10:46 AM
MDF vs fiberglass Chupa Car Audio 15 12th June 2009 11:00 PM
R19 Fiberglass ? Brownee Multi-Way 4 13th May 2008 10:26 PM
vented box & loudspeaker stuffing sstoiana Multi-Way 1 21st September 2003 02:54 PM
Stuffing in vented boxes jethari Multi-Way 14 23rd October 2002 01:33 AM
Page generated in 0.08775 seconds (73.97% PHP - 26.03% MySQL) with 11 queries
