I built 2 odd shaped cabinets for speakers that I want to use on my diy computer jukebox. I am new to making speakers and now that I have actually looked at speaker information I see that I should have figured out what speaker I wanted to begin with and decided the size of the cabinet based on the speaker, but I did it backwards. The speaker cabinets are 17" tall by 7 3/4" wide on the outside and the inner dimensions are 16" tall by 71/4" wide minus a 3/4" horizontal brace in the center. I have posted a quick drawing of the top view of a cabinet.
Can you help me decide what speakers to use in the cabinets? These are external speakers for the jukebox and I already have good speakers in the cabinet of the jukebox so I would like to go with some of the cheaper ones. They will be driven by a computer and I wired a very cheap stereo speaker up and it worked fine so more speakers won't damage the sound card over time, will they? I have been looking at the goldwood brand speakers and tweeters at partsexpress that are below $8 each and I was wondering if you could make a suggestion as to which ones to get? I think that one midrange and one tweeter in each cabinet would do it, but do I even need a tweeter? Sorry for the long message and thank you for reading it |
#2 |
I estimate your cabinets to be ~ 0.2cuft / 6L, you can add a bit more to that (10% to 20%) if you stuff them with suitable material. I am not aware of any computer sound card good at driving speakers. They will drive 8 ohm headphones to typically around 100mW / 0.1W, so speakers can be used directly but output will be very limited. Choice of drivers for 100mW only or for a more normal amplifier would be very different, the former requires efficiency emphasis. Examples of likely the best sort of thing you can do is : http://www.zaphaudio.com/ZBM4.html http://www.rjbaudio.com/Microbe/microbe.html But 100mW or so would be a complete waste of their capabilities. The cheapest suitable "proper" speakers I can find seems : http://www.geocities.com/cc00541/Scrappy.html or perhaps the coax here : http://www.apexjr.com/speakerstuff.html Mounting is a bit tricky. But if you going to use your soundcard ....... TBH I recommend a $100 pair of active speakers .... |
#3 |
You should also check for specials at Madisound. I wouldn't use anything Goldwood no matter how cheap, when for a few dollars more you could get something halfway respectable. Perhaps a single 3-4 inch Tang-Band or Hi-Vi (in which case you could check the 'full range' threads for more ideas)? Looks like the sides might not be flat enough for anything larger? Tell us more about the cabinets.
#4 |
I have decided to output the computer sound card signal to a stereo amplifier, which I will put inside the jukebox cabinet and that will allow me to hook normal speakers up. It seems that I will be able to get much better sound if I do it that way. Could you recommend speakers easier based on this? Is there a specific speaker and tweeter (if I need a tweeter) that would be good for this cabinet?
Thank you for the help! |
#5 |
The sides are pretty curved, but there is room in the cabinets for a speaker that is up to 5 inches across.
#6 | |
Hi, All the designs in post #2 will work well in that cabinet. |
#7 |
Sreten,
If I go with the vifa coax on the apex Jr website will I need to use a crossover in each of the cabinets or can I just wire the speakers to jacks on the back of each cabinet? If I need a crossover will the alesis 3 way that is listed on that same website work? Thank you for the help! |
#8 |
Hi, The above is the suggested crossover at apex jr and will cost you morethan the drivers, where it comes from no idea. The inductors are mH not uH. ![]() The Alesis 3-way crossover is extremely good value for the bits, but you have to be an inveterate fiddler with loudspeakers to make it worth buying. The mid / treble level matching is going to be wrong but there is a possibility the mid / treble c/o sections could work. There is another thread on the Vifa Co-axial : Help needed with Vifa A10CC-07 You can do worse than use the graphs in the above thread and some tools to check out the above crossover : http://www.rjbaudio.com/Audiofiles/FRDtools.html http://www.geocities.com/woove99/Spk...esigningXO.htm I can tell you the crossover above has no baffle step at all. That is OK in the above OB thread, but not for a small box. You do need a c/o and level matching between the drivers. Another option I should add is a sealed stuffed version of : http://www.zaphaudio.com/ZMV5.html That is the biggest bass driver you can fit. You can do better but it will inevitably cost more. |
#9 |
I am new to this so sorry I am asking so many questions, but what does 2.2uf, 3r, .35mh, etc mean in terms of parts? I thought they meant capicitor values, but I looked on the Apex jr site and all the values are in mfd.
I am not sure what a baffle step is, but do you know what I could add to the crossover that you posted from the previous thread for a baffle step? Thank You! |
#10 | |
The Henry is the unit of inductance. .35mH = .35 * 10^-3 Henries. Restor values can be written with an R in place of the decimal point. 3R = 3.0 Ohms. Or a multiplier with K=1000 and M=1000000; 4K7 = 4700 Ohms. |
| ESl speakers - why no cabinet? | El Zombre | Planars & Exotics | 15 | 5th October 2008 08:20 AM |
| 6x9 FR speakers - what cabinet size? | Simpleton | Multi-Way | 3 | 15th December 2005 08:38 AM |
| cabinet builders -- will these speakers fit? | Dave Jones | Multi-Way | 3 | 23rd October 2004 05:04 AM |
| Computer speakers, $150 per cabinet | Fryguy | Multi-Way | 11 | 2nd August 2004 05:45 AM |
| Sealed cabinet speakers | Zepper | Multi-Way | 3 | 21st May 2004 11:34 AM |
| Page generated in 0.12953 seconds (84.26% PHP - 15.74% MySQL) with 11 queries |
