Did it Himself
I have been looking at the website for CS Audio's Woofer Tester 2 and they mention measuring VAS by either delta-mass, test box or efficiency method.
Now what could this efficiency method be? Had a go on Google but nothing turned up.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#2 |
You can also do it with either a vented box or a vented-sealed combination.
I've never heard of an "efficiency method".
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Vance Dickason's Loudspeaker Cookbook has an equation for efficiency that includes a "K" constant (varies with Vas units you want to end up with), Fs cubed, Vas and Qes.
The WT manual simply says you can calculate it by re-arranging the eff. formula to solve for Vas - assuming you know the efficiency, Fs, Qes and K factor. If you run their basic Fx test you will get Fs and Qes. All you need then is to meas. the efficiency or use spec. sheet data and the box vol. you will use. |
#4 |
Did it Himself
Thanks. Sounds a bit rubbish, getting a consistent and accurate efficiency measurement isn't going to be that straightforward. I'll stick to using test boxes then.
#5 | |
Might be interesting to do an uncertainty analysis on that method What value and loading/boundary conditions you use to "measure" your efficiency would have a fair effect on Vas. +/- 3dB will double or halve Vas - I would stick to the test boxes or added mass method....
| What's the best method to rip CD to HDD? | kop89 | Digital Line Level | 124 | 24th June 2009 04:56 AM |
| My LP cleaning method | oshifis | Analogue Source | 23 | 12th March 2009 05:31 PM |
| FC amp, there is any method to reduce H3? | roender | Solid State | 3 | 14th June 2007 04:23 PM |
| Anyone tried this method for OTL? | jerluwoo | Tubes / Valves | 3 | 23rd November 2006 11:46 AM |
| THD measurement method | mike.e | Multi-Way | 6 | 7th October 2004 02:20 AM |
| Page generated in 0.09465 seconds (73.31% PHP - 26.69% MySQL) with 10 queries |
