Old 30th October 2008, 12:57 PM   #1
Default is L-PAD attenuator recommended for a 6 1/4 midbass?
Ive ordered a 10 inch Vifa PL26w driver for 4 ohms but It got shipped as 8 ohm driver which is making me a problem to design the crossover ... I have a 4 ohm
Midbass>
http://www.wavecor.com/html/wf160wa01.html
Tweeter>
http://www.wavecor.com/html/tw030wa02.html
Woofer>
http://www.tymphany.com/pl26wr09-08
Since i need to match the sensitivities I can get down the tweeter sensitivity to the woofer level from 94db to 87db... but how about midrange? I ve seen some threads where one doesnt advice to use a l-pad for a midrange? is it so ? then how do i match the sensitivities of these drivers ...
Another question that i have is that the woofer is said to have 6db more than the mid and tweeters since the room will absorb alot of bass... so do i need to make the sensitivity of the tweeter and the midbass to 81db? since the woofer sensitivity is 87db....
can anybody pls give me the right advice...
thanks...
Old 30th October 2008, 03:12 PM   #2
Hmmm ..........
The bass driver given its response seems to be suited to a 3 way
of 82dB to 85dB midband / treble depending on BSC amount.
You can L-pad the midrange but you need to include any effects
of the increase in source impedance on the driver Qts and the c/o.
(the same is also true for tweeters)
Alternatively go active bass / mid with more power for the bass,
you could also use active BSC on the mid driver for high efficiency
in the upper midrange and treble (90dB+).
/sreten.
Old 30th October 2008, 06:17 PM   #3
Is there anyother alternative?
Old 30th October 2008, 06:57 PM   #4
You can use a transformer/autotransformer but not common.
Or go with two 8 ohm 10" drivers per side, for 4 ohms and ~ 89dB.
/sreten.
Old 30th October 2008, 08:30 PM   #5
at present I cant afford using two 10 inch drivers per channel to do the job but ofcourse its how I wanted in the beginning but i could go with single driver for now so i think I should be happy with L-pad atten for both mid and tweets what do u say?
Reducing 7db for the tweeter and 4.5 db for midbass would be ok? to match it to 87db woofer?
Old 31st October 2008, 01:49 PM   #6
Read up on baffle step (compensation).
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spk...esigningXO.htm
http://www.rjbaudio.com/projects.html
Understand RJB's 3 way designs.
And this 3.5 way :
http://www.zaphaudio.com/ZDT3.5.html
/sreten.
Recommended Repairer welshkid Solid State 1 12th June 2008 08:39 PM
Recommended diy Pre for T-amp t. Class D 12 21st June 2005 09:56 AM
Recommended 2-way for beginner Dave Bullet Multi-Way 5 28th February 2003 09:57 AM
Page generated in 0.08411 seconds (74.07% PHP - 25.93% MySQL) with 10 queries
