Old 30th October 2008, 04:52 AM   #1
Default Driver suspensions
Is there any practical way to center a voice coil (and former) that is NOT affected by static friction and does not resort to the use of a spider? e.g. a sliding linear bearing can definitely locate the coil former but is affected by a small amount of static friction which would basically brick-wall any signal causing less than a certain amount of force on the coil.
I'm aware of the Hartley magnetic suspension, but there must be another way to do it all mechanically.
Old 30th October 2008, 04:59 AM   #2
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
what about the dome midranges? and dome subwoofers...
Old 30th October 2008, 05:04 AM   #3
I don't know that they use anything other than a conventional suspension. Never heard of a dome sub, anyway.
Old 30th October 2008, 05:06 AM   #4
there is no spider in domes. the mark audio alpair 5 also has no spider.
Old 30th October 2008, 05:10 AM   #5
Didn't know that. Domes tend to perform badly after going past a certain size, though. Still, I appreciate the input.
Old 30th October 2008, 05:12 AM   #6
what is wrong with spiders? they help provide dampening
Old 30th October 2008, 05:14 AM   #7
Specifically, they provide returning force and a little damping. However, they are never ideal springs, and this contributes to distortion. They do have the benefit of both returning and locating the coil former, though.
Old 30th October 2008, 11:27 AM   #8
tinitus is offline tinitus  Europe
Fore "spider" you can use an arrangement of threads
Works fine but maybe not ideal fore big Xmax
Old 30th October 2008, 01:55 PM   #9
You can make spider-like suspensions (something with rolls) to act very, very close to an ideal spring over a given excursion range if you design it correctly. That doesn't mean there won't be other problems - resonances, etc. Anyway, typically you'd want a flat spider (no cups), and smaller radius rolls near the voice getting larger towards the OD. However small tweaks can sometimes make significant differences in the compliance curve. Another thing to consider is that unless you're trying to push the driver to its limit, the distortion produced by a spider is typically not high order so will not be as audible as other issues. Another thing to consider it that even if you have a non-linear driver suspension, if you are putting it in a relatively small enclosure where the enclosure compliance swamps the driver compliance, air is a pretty linear spring (unless, once again, you are going to the limits - having a really small enclosure and moving the cone enough to significantly change the volume of the enclosure).
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
DIY TT Exotic Suspensions makinson1 Analogue Source 7 8th May 2007 07:29 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.10090 seconds (78.14% PHP - 21.86% MySQL) with 10 queries
