Does anyone know of any guidelines about estimating the leakage (Ql), absorption (Qa), and port (Qp) losses that need to be factored into a box design? I know that they can be changed in the programs I have evaluated like WinISD Pro and Speaker Workshop. I am not sure if the port loss is a function of its size (diameter and length) or not.
Anyone know where I could look? Not sure if these could drastically change the size and/or performance of the system if not estimated accurately. Thanks. |
#2 |
Vance Dickason's "Loudspeaker Deesign Cookbook" devotes some ink to your question. Pick up a copy. It's a great reference.
#3 |
Thanks speakerdoctor.
I blew the dust off of my 5th edition of the Loudspeaker Cookbook and read up on it. According to Vance, in practice, Qa and Qp tend to be so low that they are not significant. Ql is assumed to be 7. If one were to test further for it, a box would be constructed to proper size and an impedence test would be run. With a few select datapoints from this test, an actual value of Ql can be calculated from the equations he presents. |
#4 |
"According to Vance, in practice, Qa and Qp tend to be so low that they are not significant."
He devotes a section to losses due to port compression, which obviously means they aren't insignificant.
----------------------------------------- Noah |
#5 |
Qa, Qp and Ql can be measured easily only if one dominates such that the others can be neglected. If you curve fit the impedance curve, you might be able to extract useful values.
The best reference on linear T/S theory I know of is J.E. Benson's book "Theory and Design of Loudspeaker Enclosures" - which is out of print, but available at very high cost online. This book is written for engineers (very mathematical) and doesn't really have worked out examples, just hints at how to do it. If you contact TAB books, they might print one on demand for you if they still can legally. As you said it (Qp at least) changes with level....so for your model to be useful it would have to be predictive of the changes with level. The SoundEasy manual (available online) has a model that was cooked up to predict changes in port losses with level. Once you go nonlinear, you might as well start modeling other nonlinearities as well, which can get complex very fast unless you are just fudging.... To avoid all that effort, I would just stick with the 17 meter per second (5% of the speed of sound) rule on port velocity and be done with it.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#6 |
noah,
About the only section I see is titled Vent Resonance and Mutual Coupling. It doesn't deal with specific losses due to the vent (Qp). |
#7 |
IIRC I have editions 4 and 5, and it was in both of them.
If feasible with your box size and Fb, I'd take Ron's advice.
#8 |
Noah,
Yeah, he does offer some good advice. |
| help !! calculating switch losses | dead rat | Class D | 0 | 16th December 2008 03:33 PM |
| Reverb insertion losses | ThSpeakerDude88 | Tubes / Valves | 5 | 28th January 2008 02:50 PM |
| Mesure box losses | REALFLEO | Multi-Way | 2 | 7th February 2007 01:06 AM |
| Port Midrange Leakage | jimangie1973 | Multi-Way | 26 | 24th January 2007 09:37 PM |
| Question about Damping, Leakage and Port Q | philiprst | Multi-Way | 0 | 26th May 2004 05:54 PM |
| Page generated in 0.09816 seconds (75.08% PHP - 24.92% MySQL) with 10 queries |
