Old 29th October 2008, 12:36 PM   #1
mhtplsh is offline mhtplsh  India
Default insert t nuts
When making big subwoofer cabinets t nuts & insert nuts r used.
HI hv attached the picture of the 3 different type of inserts used in box making.
Which is better among this?
Old 29th October 2008, 12:46 PM   #2
I would expect all of these to work adequately.
The two with the 4tang arrangement may need pilot holes if the board is particularly hard. Some grades of MDF (HDF?) seem to always bend the tangs.
All of them are inserted from the back and very effectively clamp the board between Tnut and driver frame.
regards Andrew T.
Old 29th October 2008, 01:07 PM   #3
You might check out the PartsExpress site, they have the "T" nuts with an extra tang for additional grab.
Pete
Old 29th October 2008, 01:32 PM   #4
Send a message via Yahoo to angshudas
Default Re: insert t nuts
Could you get these T nuts in India.
Old 29th October 2008, 02:23 PM   #5
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
All three could work, but as said the tangs can bend over. The kind in the middle is my preferred type, but I augment the holding power by putting a drop of epoxy in the hole before press fitting the insert nut.
I don't like the screw in kind (not shown) because they never go in orthogonal to the work piece without setting up a jig and using the drill press to screw them in. Which...is annoying.
-Scott
www.stuffscottbuilt.com
Old 29th October 2008, 03:00 PM   #6
Did it Himself
richie00boy's Avatar
I use the screw in type and while it's difficult to get them square if you screw from the back after the cabinet is built, I had no problem just putting them in by hand with an allen key to the panel before it was glued to the box. This was with MDF, it's probably harder with plywood.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 29th October 2008, 03:04 PM   #7
jackinnj's Avatar
Default Re: Re: insert t nuts
We use the ones in the middle -- "thickified" epoxy or cyano-acrylate adhesive with poly fibers in it works extremely well. The CA can cure almost instantly.
Old 29th October 2008, 05:45 PM   #8
AMV8 is offline AMV8  United Kingdom
Hi
I would expect them all to work.
However in practice I use a nut with a plastic insert and glue that to the cabinet. If I can not use that I use a very small amount of car gasket compound and add it to the bolt thread to stop the nuts working loose with use.
Don
Old 29th October 2008, 09:05 PM   #9
mikela is offline mikela  United States
Hi mhtplsh,
Here is an approach that I used http://www.htguide.com/forum/showthread.php4?t=29922 . You can see the end results for me and some additional commentary here http://www.htguide.com/forum/showthread.php4?t=29968 .
HTH
Mike
Old 29th October 2008, 09:48 PM   #10
frugal-phile(tm)
planet10's Avatar
The one in the is not actually a t-nut, it is called a threaded insert. These are more reliable than a t-nut. I'll only use a t-nut in an application where i can get at both sides without removing the device it is holding (only 1 experience with having to find a way to remove a driver after the t-nut spins loose was convincement enuff)
When installing these i use 1 or more sacrificial bolts & some washers to slowly pull the t-nut or threaded insert into position. This ensures a square fit and a more secure installation.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Which insert nuts for FE206E? quadtech Full Range 1 26th December 2008 11:37 AM
Insert comment here... EV2181 Multi-Way 5 4th September 2008 07:42 AM
How to insert a photo into your post anatech The Lounge 24 7th February 2008 04:29 PM
UK threaded insert suppliers ? RobWells Multi-Way 3 29th September 2006 11:22 PM
how to insert diagram in post fazman Multi-Way 3 23rd August 2005 01:31 AM
Page generated in 0.10721 seconds (80.03% PHP - 19.97% MySQL) with 11 queries
