I'm searching a good 12" kewlar or carbon, and SPH300-KE seems to me a sort of ETON at half price
It will must be filtered at 250- 300 Hz ala Thiel ( 6dB/oct).
Do you think it is a good driver? Is it well "punchy" ?
Frequency response looks good on the monacor datasheet, maybe too much beautiful to be true
Any comment will be very appreciated
Paolo
Paolo
Hi interal,
I am just busy to fabricate speakers for my colleague. If you didn't notice high-end Dáppolito topic.my project
I just send back both monacor SPH250CTC. You can hear the voice coil rub and tick the pole piece damaged due transport or fabrication failure.
But what I did notice Monacor claims 200W nom. and 300 muzik power.
But the truht is the chassis reaches its X-max at 20 Watt.
It did work down to 18Hz do very nice performance.
So i did check up the sph300ke and I thought it was 80 watt when it reaches x-max.
This is what I mean the X-maxes off sph250 and 300.
http://www.bmm-electronics.com/Product.asp?Product_ID=7005
This 12" Kevlar Hivi seems ok with +/-6mm Xmax and affordable
Thanks Helmuth,
Nice project.
It is a pity for the voice coil.......I hope you 'll more lucky with the next woofer !
I'm not so interested in subwoofer performances; I'm searching a punchy bass , strong and fast
If someone has a Hobby-hify test report for the frequency response measured......
Paolo
Nice project.
Paolo
Paolo
I have build a backloaded horn with 4 ti100 visaton active two way.
Extreme fast impulse gave a transparent sound.
See this one
horn
Helmuth said:Hi interal,
I just send back both monacor SPH250CTC. You can hear the voice coil rub and tick the pole pies damaged due transport or fabrication failure.
I had similar problems with a Monacor SP-165GI... suspension of the cone was not correctly glued to the chassis.... sent back... another week waiting...
Monacor makes me crazy, and I suspect that frequency response curve (and other data) are not so correct.
For testing, I'm trying to build something to connect to a PC soundcard, but I have some problems in calibrating a normal mic....
- Any experience with Monacor SPH300-KE ?
