Old 30th October 2008, 09:38 AM   #31
That gives me an idea - hiding a still in a speaker...
Old 30th October 2008, 09:56 AM   #32
Originally posted by pjpoes
over dampened typically means that the cabinet is smaller and thus the Q is higher. I think there is a lot of confusing information out there about this, which I can only guess comes from old vs new design. Many designers will call .5 critically dampened, some even go so far as to say .7 is critically dampened. They refer to this as high Q, and over dampened, then say that 1 or higher is very high Q and very over dampened.
Actually, there's a lot of confusing information in your own posts, rather than just other people's.
.707 is usually good compromise, altho slightly lower often tends to work best in a typical listening room. Somewhere around .577 is also sometimes considered. .5 is critically damped. Under .5 is over damped. Anything much over .7 I usually refer to as over damped.
andy2, nice wood floor btw.
Old 30th October 2008, 10:13 AM   #33
stoolpigeon's Avatar
Damping and Q or Quality factor have precise definitions.
My mother always told me that if I didn't know what I was talking about I should keep my mouth shut.
Unfortunately she was pre internet.
sp
Old 30th October 2008, 11:02 AM   #34
breez is offline breez  Finland
Default Re: cabinet Q
It seems to me that when a room and loudspeaker are considered as one system the differences between 0.5 and 0.707 Q are miniscule. Ever do a measurement of a typical listening room in the modal region? I can guarantee you will find several resonances with very high Q.
Old 30th October 2008, 11:06 AM   #35
Did it Himself
richie00boy's Avatar
Sorry pjpoes you are wrong.
Over damped means the response to a square wave shows rounded corners, which is what happens when the box is made big (assuming Qts<0.5). The amplitude response will also be droopy.
Under damped means the response to a square wave begins to ripple, which is what happens when the box is made small. The amplitude response can be anything from showing a peak, through maximally flat, to just a tiny bit of droop.
Critically damped is and has always been Q=0.5, this is as good a perfect rendition of a square wave as you will get.
Under damped means some ripple of the square wave. With Q=0.707 although the amplitude response is maximally flat the square wave response shows a little peaking, it's slightly under damped.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 30th October 2008, 12:44 PM   #36
Right, flat response and critical damping don't occur at the same Q. All logical arguments aside, I've never liked sealed systems with the typical Q, but think they sound better up around 0.9- and I'm not a fan of thumpy bass. IMO, the best bet might be a Q around .5, but with equalization to correct the drooping response- assuming one has the power and the speaker can handle it.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 30th October 2008, 01:51 PM   #37
Line level EQ is another option, it always works,
it never fails to improve matters to some degree.
/sreten.
The easiest way to reduce box volume DAMIC Multi-Way 7 17th July 2009 05:51 AM
Speaker has a bit too much energy at 500Hz, how to reduce this Tino Multi-Way 7 7th May 2009 04:01 PM
Is there a way to reduce brightness of a speaker thermonuclear Car Audio 11 22nd October 2007 03:19 AM
speaker surgery: reduce winding height capslock Multi-Way 1 2nd August 2004 07:49 PM
Reduce difraction and distortion from the cabinet on DIY designs. Bedroc Multi-Way 1 24th February 2002 03:09 AM
Page generated in 0.10456 seconds (77.43% PHP - 22.57% MySQL) with 10 queries
