Old 26th October 2008, 06:53 PM   #1
Daveis is offline Daveis  United States
Default Why Scanspeak rising frequency response in woofers??
Scanspeak designs a rising frequency response into their woofers above 1kz.
How does one handle this in the crossover?
Why is it meant to make the crossover simpler?
I guess Scanspeak is ASSUMING you will use a particular crossover, but I don't know what that is..
Help.
Old 26th October 2008, 07:03 PM   #2
tinitus is offline tinitus  Europe
I use a 5" SS Revelator midwoofer in a 3way, and it needs a "notch" filter
In a 2way many will "attack" the driver early with a big inductor to deal with BSC, and at the same time deal with the rise and probably what you refer to as "simple" xo
Old 26th October 2008, 07:51 PM   #3
If you're reading their graphs I think it's because they don't include BSC and they test in a smallish sealed enclosure.
Old 26th October 2008, 08:36 PM   #4
I've seen comments like this. Trying to understand maybe with an example crossover what this means.
Are there any reference designs for 8831G, 8530K, etc. from Scanspeak that show how they expect the driver to get used?
http://www.htguide.com/forum/showthread.php4?t=10944
Also, classic SS drivers have that tiltup above 800 Hz so that you can use a single pole in the crossover around 250 and not have to play as fancy an impedance control tricks to put a zero in the response to stop the BSC - hence the 800 Hz rise. It can simplify the crossover. BUT, one side effect is that the cone's first mode is at 800 Hz, creating a coloration. I used to use these SS drivers in the early 90's, but haven't for a long time- I find I prefer pistonic performance to beyond the crossover region- midrange is clearer.
Look at
http://www.tymphany.com/files/produc...5W_8531K00.pdf
http://www.tymphany.com/files/produc...5W_4531G00.pdf
Why the heck would you want the on-axis woofer response to go up 4-6db's, have the off-axis response drop like a rock from 2khz on, but have the on-axis response shelved high out to 5khz?
And then the Illuminator,
http://www.tymphany.com/files/produc...WU_8741T00.pdf
What is happening at 5khz on that driver?
Old 26th October 2008, 08:42 PM   #5
Sorry, I misread 1kHz. Can't help you there.
Old 3rd December 2011, 06:54 PM   #6
Default Hi
Thread is 3 years old, but I have pm you.
www.mariopankov.com
beta 8a rising response? AudioGeek Full Range 1 27th April 2009 08:45 PM
Is high frequency rising-up OK? Peter Huang Pass Labs 3 4th August 2007 10:32 PM
Taming rising frequency response 'naturally'... Taperwood Full Range 31 12th May 2006 02:50 AM
How would you aproach this rising frequency response? swak Full Range 6 4th November 2004 08:30 PM
Handling a rising response rick57 Multi-Way 7 12th March 2003 09:53 PM
Page generated in 0.10194 seconds (69.16% PHP - 30.84% MySQL) with 10 queries
