Newbie here at this forum and to diy speaker building. Being a novice (actually first time build) I need some suggestions. Picked up some Sony ss-m3 crossovers, no drivers, or cabinets. Other than knowing these were sealed,non parallel enclosures this is the extent of my knowledge. Vifa, Peerless? 4ohm/8ohm?
I have some Polk Audio R10 5 1/4 4 ohm raw drivers I would like to use.Poly mica cones, rubber surrounds,50rms/100 peak, 80-4000hz.87 db 2.83v/1m. Previously unassembled cabs are 3/4 mdf w/1 1/2" baffles.7"w x 24"h x 8"d (outside dimensions)no holes cut and 2 internal braces/dividers per cab. WTW or WWT configuration? Realizing that these x-overs are for a sealed cab and these drivers are normally used in ported cabs will this present a problem? Will my smaller cabs/drivers "choke" the properties of the x-overs? Yeah I know I picked quite the complex project to start with and with my limited knowledge it is pretty much a shot in the dark. I had previously purchased the drivers (8@ 6.00 each) 2 cabs (10.00 each) x-overs (20.00 pair)As you can see this is a shoestring build. Still have no tweeters. Any and all suggestions or comments would be appreciated. Grumpops |
| Need help with Sony SA-WX700 subwoofer drivers... | chops | Subwoofers | 18 | 6th September 2007 04:05 PM |
| Cheap little Sony Drivers | Smokehouse Bob | Full Range | 9 | 30th January 2007 02:18 AM |
| old Sony R2R drivers | pjanda1 | Full Range | 3 | 31st March 2006 03:00 AM |
| need help about sony drivers | sidd_raj2002 | Subwoofers | 0 | 22nd November 2004 10:35 AM |
| Page generated in 0.06139 seconds (67.68% PHP - 32.32% MySQL) with 10 queries |
