Old 25th October 2008, 12:20 PM   #1
Default adding mass to cone
It is possible to determine the T/S parameters by adding mass to the cone. Is it ever done to add mass permanently. What are the pro's and cons?
Old 25th October 2008, 05:31 PM   #2
gedlee is offline gedlee  United States
Added mass is probably the most common technique. Just make sure that you keep the added mass close to the voice coil connection to the cone. I have used clay but I prefer solder pieces (heavy lead) with a little dry adhesive as it makes a tighter fit to the cone - added mass must be firmly attached to work right.
I have added mass to a speaker in subwoofer apps for example. I just glue on pieces of solder. Balance it as well as possible.
Old 25th October 2008, 10:04 PM   #3
Is there method for calculating the new specs?
Old 25th October 2008, 10:49 PM   #4
I dont' think so. You'll need to run a test with a dedicated woofer tester instrument. They are for sale at PE.
The classic Snell Model A used add mass on the RCF 12 inch woofer. They poured a resin around the porous dust cap to about 1/2 inch depth. It lowers the Fs and efficiency is sacrificed as the trade-off.
Old 25th October 2008, 11:22 PM   #5
If you look up the basic equations for TS parameters its easy to see what added mass will do. It lowers Fs and raises both Qes and Qms.
Old 26th October 2008, 12:04 AM   #6
MJL21193's Avatar
There are other options.
For next to nothing with Speaker Workshop and a handful of parts.
Old 26th October 2008, 05:17 PM   #7
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
WinISD Pro can simulate a box and allow you to add mass to the driver to see the effect it will have on the driver in that box. Ideal if your doing a ported or sealed box
Old 26th October 2008, 05:33 PM   #8
HK26147 is offline HK26147  United States
For purposes of testing "poster caulk" ( sold at office supply stores ) works ( see audioXpress November 2008 p 35 ).
Usually 200 grams or less is used.
For permanent application - lead ( as in solder recommended above ).
Also lead foil is sold in golf pro shops
Old 27th October 2008, 12:18 AM   #9
I have the free version of WinISD. How do i make the changes to simulate additional weight?
Old 27th October 2008, 01:40 AM   #10
Moondog55's Avatar
This is just a thought as I've not tried it, but would epoxy with a suitable filler like barium oxide or powdered nickel be any good for adding mass permanently??.
I ask as I still have a litre of West Systems epoxy and powdered aluminium and stainlees stell left over from a heatsink experiment.
Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Adding cone mass fdeck Multi-Way 12 17th June 2009 06:06 PM
Low Qts drivers : Adding mass 316a Multi-Way 20 4th May 2006 02:27 PM
Can somebody explain the pros/cons of adding cone mass? GuyPanico Subwoofers 25 16th April 2005 03:50 AM
Adding mass to PR.... hofffam Subwoofers 1 7th January 2005 12:01 AM
Page generated in 0.16240 seconds (56.71% PHP - 43.29% MySQL) with 10 queries
