Old 24th October 2008, 10:11 PM   #1
sdclc126's Avatar
Default Bracing Mods for P.E. Cab
Hello,
I've ordered a pair of the P.E. 0.38 cu. ft. cabs. I am wondering if anyone has added bracing in addition to the vertical shelf brace they come with - it seems they could benefit from some horizontal bracing also.
Has anyone done this, or is it even recommended? The rear area behind the shelf brace I guess would be pretty much impossible to get to - maybe some ribs back there, but perhaps the front area could benefit. I was thinking of a horizontal shelf attaching to the front side walls and the area of the vertical brace in between the two big holes - or? It wouldn't attach to the baffle because I want to keep it detachable.
I'm aware that internal volume will be reduced - I will drill holes.
Thanks for your input.
Soft Dome
Old 24th October 2008, 10:12 PM   #2
frugal-phile(tm)
planet10's Avatar
You got the rectangular ones (really need work) or the curvy cabinets (just toss the baffle)>
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th October 2008, 10:25 PM   #3
sdclc126's Avatar
The rectangular ones - I forgot about distinguishing from the curved.
Soft Dome
Old 24th October 2008, 10:41 PM   #4
frugal-phile(tm)
planet10's Avatar
Can i ask why you chose those over the curved ones... the latter are much better boxes.
Can you post a pic of the insides?
dave
Old 24th October 2008, 10:54 PM   #5
sdclc126's Avatar
I chose them because I want to add bases and make them into floorstanders - not about to try that with the curved ones.
I have a bunch of 3/4" MDF - I was thinking of just making them wider by putting new side panels on, of the total height I want. Can do this with the rear too. This would be in addition to internal bracing. The three long sides would then be 1.5" thick.
The pic is from PE's site.
Soft Dome
Old 25th October 2008, 12:46 AM   #6
frugal-phile(tm)
planet10's Avatar
Seems a waste to do that... you go that far you might as well start from scratch. The finish on these is the only reason i can see to get them.
dave
Old 25th October 2008, 09:56 AM   #7
Moondog55's Avatar
I take it these come already assembled?? in that case about all you could do is add some inch by inch square at each junction to couple the panels together, maybe some bits of scrap at random places on the flats but that may be a lot of work for minimum return
EDIT
as for height just make a decent stand with the MDF you have
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 25th October 2008, 04:52 PM   #8
sdclc126's Avatar
Yes they come pre-assembled, which is what limits what you can do inside. And yes the small wood pieces to join the junctions is in the plan - I've done it with other cabs. I'll do the horizontal shelf brace I mention earlier too - don't think it can hurt.
Thanks.
Soft Dome
Does A Box Like This Need Bracing? sdclc126 Subwoofers 10 12th May 2006 01:31 AM
Enough bracing? Vikash Multi-Way 51 8th May 2006 05:58 PM
how much bracing is enough gwgjr31 Subwoofers 1 5th May 2006 06:57 AM
do I need bracing for a 15L BR? RockysDad Full Range 12 11th August 2005 07:18 PM
enough bracing?? Chris8sirhC Multi-Way 3 31st January 2004 08:16 PM
Page generated in 0.12536 seconds (66.68% PHP - 33.32% MySQL) with 11 queries
