Old 22nd October 2008, 02:26 PM   #1
GK is offline GK  Australia
Default Which wood for cabinet (?) and double check on driver selection.
Hi Ho.
I’m about to splash out on the drivers for my first serious speaker build – a slim 90dB/1w floor standing 3.5-way WWMT tower.
My driver selection is as follows:
Tweeter (91dB)
http://www.soundlabsgroup.com.au/p/V...MHT+12+-+8+Ohm
Midrange (90dB)
http://www.soundlabsgroup.com.au/p/V...50+FFL+-+8+Ohm
Bass (90dB)
http://www.soundlabsgroup.com.au/p/V...+250+S+-+8+Ohm
Bass reflex box for the woofers (rear port) and crossover frequencies of 800Hz and ~5kHz.
I intend to implement a full 6dB of baffle step compensation by rolling of the bottom woofer.
As far as I can tell this driver selection will work well in the intended configuration, but I though I’d float the combination here in case I’ve missed something important.
As for the cabinet I can build it in MDF, ply or solid pine. My current preference is for MDF because it is cheap and very easy to work with.
However if there is a convincing case to be made for either Plywood or pine I could be persuaded.
I’m also looking for an affordable measurement microphone / frequency compensated preamp. Any suggestions?
Glen
Old 22nd October 2008, 02:54 PM   #2
MJL21193's Avatar
Hi Glen,
You know you are making a big mistake and you really should go with an established design...
Those look like nice drivers. Higher price doesn't always equate with better sound though.
I see you want to cross higher than you should on the woofer. It's published response looks pretty ragged up there.
The plan is for a 2.5 way?
For box material I'd stay well clear of solid pine or any solid wood for that matter. Unless you have the skill to construct it to accommodate seasonal expansion, it's just asking for trouble.
IMO there is WAY too much emphasis put on material differences. Superior construction techniques will always negate any real or supposed differences. MDF would be fine.
Old 22nd October 2008, 09:12 PM   #3
PB2 is offline PB2  United States
PB2's Avatar
Originally posted by MJL21193
Hi Glen,
You're joking or did you not really read the post? It's a 3.5 way, both woofers will be rolling off at 800 Hz - should not be a problem. I did not take a close look so I won't comment further. He won't learn anything going with a proven design.
Pete B.
Old 22nd October 2008, 09:21 PM   #4
MJL21193's Avatar
Originally posted by PB2
You're joking
Wow Pete. Perceptive.
Old 22nd October 2008, 09:38 PM   #5
Andy G is offline Andy G  Australia
Andy G's Avatar
so... all the major vocal fundementals will be delivered by the 10" bass drivers ?
Old 22nd October 2008, 10:15 PM   #6
MJL21193's Avatar
All joking aside. I mistakenly typed a 2 instead of a 3.
I wouldn't go as high as 800Hz with that or any other 10", that's what an appropriate midrange is for.
Old 22nd October 2008, 10:43 PM   #7
Andy G's Avatar
that's what I was sort of saying, wondering about etc
Old 22nd October 2008, 11:07 PM   #8
MJL21193's Avatar
Andy!
You've changed your handle?
Brother of Kenny? Can you play sax? I love sax.
Maybe Glen has been reading Geddes. He takes a 12" or 15" right up to near 1k.
Old 22nd October 2008, 11:49 PM   #9
Moondog55's Avatar
Hi Glen, just my 2 cents worth; it's a good driver but I tried a clone of it and just doesn't work with a woofer that big.
Soundlabs have some efficient 5 and 6 inch mid-bassfrom Visaton that IMO would work better.
That said I'm glad to see that you are going to do your own thing, it's the only way some of us learn anything
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 23rd October 2008, 12:36 AM   #10
Andy G's Avatar
Andy!
I'm Andy G on every other forum.. Thought a bit of consistency was in order
not brother of Kenny, cannot play sax
I love s.x, too.
Earl is using PA drivers, and as far as I can see, is crossing to use the directivity of them.
The drivers he uses are more like a PA mid, and still do vocals quite well.. Normal HiFi bass drivers on the other hand ....
Can I get a double check on my cabinet? saabracer23 Subwoofers 23 9th June 2009 07:34 PM
Making a bass cabinet, driver selection. ruerose Instruments and Amps 21 29th October 2006 02:48 AM
Page generated in 0.15115 seconds (75.00% PHP - 25.00% MySQL) with 11 queries
