Old 21st October 2008, 09:10 PM   #1
Default Efficiency question
Is it possible to go higher than 112dB/watt since it correspond to an efficiency of 100%? If so, how is it possible?
Thanks.
Do your way, it's the only way.
Old 22nd October 2008, 01:51 AM   #2
simon5 is offline simon5  Canada
Maybe it's possible if the coupling medium ain't air. Other than that, I think it's impossible.
DIYaudio for President !
Old 22nd October 2008, 01:54 AM   #3
Many compression drivers go beyond 112dB/watt. Just looking for a mathematical explanation.
Old 22nd October 2008, 02:02 AM   #4
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Yes, at least it can appear to be greater than 100%.
Consider that speaker, particularly a horn can also confine the radiated energy into a space smaller than full spherical.
This is referred to the Di or horn Q, for example a horn with a Q of 10, has 10dB of gain over an omnidirectional point source.
Best,
Tom Danley
Bring back mst3k and futurama
Old 22nd October 2008, 02:13 AM   #5
How about an array of say 36 drivers each 100dB/watt in series ( 6) // ( 6) configuration. Net acoustic gain should be 15db. In practice, is 115dB possible in half space with 1 watt?
Old 22nd October 2008, 03:58 AM   #6
Speakerholic
Cal Weldon's Avatar
Compression drivers are rated when mounted on a horn.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Full Range Line array Efficiency and Impedance Question? rjp366 Full Range 10 23rd August 2009 06:42 PM
Hi Efficiency two way? Godzilla Multi-Way 24 15th August 2008 04:02 AM
A question about back loaded horn efficiency BHD Full Range 13 13th December 2006 07:15 PM
Question on efficiency if PWM amps and PS noah katz Class D 33 3rd July 2006 07:26 AM
Question Of Efficiency gpsmithii Multi-Way 3 5th May 2006 05:55 PM
Page generated in 0.07689 seconds (72.83% PHP - 27.17% MySQL) with 10 queries
