Why do they place  tweeters far from the mid-bass?
Old 21st October 2008, 11:34 AM   #1
poldus is offline poldus  Europe
poldus's Avatar
Default Why do they place tweeters far from the mid-bass?
I would welcome your comments on why so many designs place tweeters quite away from mid-bass drivers. Shouldn't they be as close together as possible to aproach an ideal point-source response? What are the benefits, if any, of those designs?
Old 21st October 2008, 03:13 PM   #2
diyAudio Member RIP
The short answer is that modern designs do not do this.
They are nearly always fairly close and vertically aligned.
/sreten.
Old 21st October 2008, 03:35 PM   #3
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Which designs place the tweeter so far from the midbass? Yes they should be very close, though its somewhat frequency dependent. Lower frequency points for the crossover would allow them to be farther away and still sum acceptably.
Old 21st October 2008, 03:48 PM   #4
poldus's Avatar
The number of speakers with tweeters widely spaced from mid-bass units is huge, ranging from extreme cases of over 10 inches to miriads of examples of tweeters that do not have their rims touching those of their bass partners, when they easily could. Instead, they opt for separating them from a couple of inches to often quite a bit more.
Even when the crossover frequency is low enough, isn't it still better to place them as close as you posibly can?
Makes me think those engineers are prioritizing benefits i am not aware of.
Old 21st October 2008, 05:00 PM   #5
Undefinition is offline Undefinition  United States
I don't know if his site is still up, but I remember somewhere on Wayne J's speakerbuilder.net (I think it was the Eros writeup) that he mentioned that, in his experience, spacing the mids and tweeter a bit farther than normal could sometimes create a bigger soundstage.
Is it true? I have no idea. I've designed speakers with the mids and tweeters pretty much touching, and ones with an inch or more between the two drivers. In the end, that bit of driver spacing had a far smaller impact on the overall sound than whether the design was a TM or MTM. And really, the largest factor in the driver integration was not their physical layout, but the crossover design... like, by a mile.
-Paul Carmody
https://sites.google.com/site/undefinition/diy
Old 21st October 2008, 06:12 PM   #6
well spacing them farther might give the illusion of more space as it would create more summing issues, especially in the power response.
It really doesn't matter if they are a few inches if that space is smaller than the wave length at the summing frequency, so I would argue that, no, its not better. As for ten inches, while I'm sure there are some, I haven't seen many. I'm just wondering if you could show me some, I would want to see if there appears to be logic behind the design.
Now if by ten inches you are referring to large horn systems, that is a different story. The same laws apply, but typically horns are crossed over quite low, and the edge of the wave is different than with a dynamic driver, so spacing can be a little different.
Old 21st October 2008, 07:02 PM   #7
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Sometimes aesthetics are given more weight than performance. "If you can't make it sound good, make it look good"
Spacing also causes awful lobing problems with horns, but most people building that kind of speakers are more focused on luxury furniture-like finishes and exotic vintage drivers that on optimum power/polar responses.
Theoretically, the angle at which the main vertical nulls and lobes happen depends on driver spacing, but I feel this is seldom taken into account. Floor and ceiling reflections may be reduced if the optimum distance is used, but complex polar measurements are required to optimize this.
I use to feel like the small child in The Emperor's New Clothes tale
Old 21st October 2008, 08:45 PM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Avalon Asscendant
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st October 2008, 09:01 PM   #9
MisterTwister is offline MisterTwister  Tibet
search for M8ta at HTguide
Old 21st October 2008, 09:14 PM   #10
Avalon acoustics designs more for looks than sound in my opinion. They claim the design is to reduce diffraction effects, but the crossover points are far too high to not have lobing issues, and all the response measurements of their speakers I have seen suggest that the design is compromised. Having said all that< i've not heard any of their speakers.
With horns, I didn't mean to say that horns don't need proper spacing, just that they can look like they are spaced too far apart, but really are fine based on summing points and radiation from the horn.
Why do they place  tweeters far from the mid-bass?Hide this!Advertise here!
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 20 27th July 2016 07:11 AM
Helmholtz bass absorber, where to place? banana Multi-Way 3 26th July 2006 04:13 PM
Wanted- Tweeters and drivers(bass to mid) Dannyball Swap Meet 0 7th January 2005 11:51 PM
Accuton Tweeters - Mid/bass match? toxinlab Multi-Way 3 21st September 2004 05:53 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Copyright ©1999-2017 diyAudio
