Old 19th October 2008, 11:58 AM   #1
Default Which 8" driver
I want to build bass units for my mini monitors (http://www.avforums.co.za/index.php/topic,2060.0.html).
I am after clean, well defined bass that extends as low as possible without compromising musicality.
The drivers that I am looking at include:
Silver Flute W20RC38 (or the 4ohm version) @ 36.80
HiVi M8a @ $56
Peerless 830667 @ $52.75
Seas CA22RNX (H1288) @ $87.75 (very expensive!)
All of them appears can go down to 30-32 Hz (except maybe to Silver Flute). Which one would you recommend? The idea is to cross between 200 - 400Hz (haven't done ANY design yet). The bass drivers will be in their own enclosures with the mini monitors sitting on top.
I realize that the drivers are not all in the same league but they won't be used in their full range capacity. Are the CA22's worth their price in bass only application?
I'd appreciate your suggestions.
Gerhard
Old 19th October 2008, 12:39 PM   #2
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
The M8a is very well regarded when used below its breakup, which you would be in your application. I have one in a sub and it can produce very clean bass. They also look great, especially when set in to the baffle as they are designed to be. Would look nice with your lovely monitors
See the M8a excursion in my vid here:
http://www.youtube.com/watch?v=xBhDC6fYI6Q
Its remarkebly clean for quite a basic motor. The cone is exceptional apparently.
Old 19th October 2008, 01:54 PM   #3
What about the Dayton RS225S-8 @ $55.11?
Old 19th October 2008, 02:12 PM   #4
Dr.EM's Avatar
That would also be very good. With your low crossover point that should produce similar results to the M8a. Up higher I believe the Dayton's breakup is less controlled. The Dayton may actually have a lower distortion motor and appears to have more Xmax. This might be worth looking at:
http://www.audioheuristics.org/measu...fer%20test.htm
Old 19th October 2008, 02:21 PM   #5
I did look at that, hence the suggestion
It is a toss-up between the Dayton and the HiVi it seems. All else being equal I'd go for the Dayton because it is black (I don't know about that orange ) and shielded. I guess I can paint the HiVi if I don't like the color. I haven't seen them in real life though, I might like them after all!
Old 19th October 2008, 04:06 PM   #6
Dr.EM's Avatar
You wouldn't want to paint them, they are really attractive in real life . Got a very fine texture that makes the cone matte looking, its quite bronze/wood colour really.
Old 19th October 2008, 04:32 PM   #7
Speakerholic
Cal Weldon's Avatar
Don't forget about the offerings from TB. I have had good luck with the 6.5" version of this neo unit
http://www.partsexpress.com/pe/showd...number=264-833
This little workhorse I have in a bi-amped 4 way and it sure holds it's own
http://www.partsexpress.com/pe/showd...number=264-854
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 19th October 2008, 05:10 PM   #8
frugal-phile(tm)
planet10's Avatar
My favorite 8" at the moment is the CSS SDX7. Needs a bit of tweaking to clean up the kevlar but performs more like you'd expect from a larrger driver. Works well in a sealed box. More expensive thou than any of your candidates.
We have been playing with the 5" Silver Flute as an inexpensive alternative -- for the money very good, the 8 is on the radar to play with in the future.
Even 200 Hz sounds a bit high to XO unless you are going for shear volume levels. You going to go active for this XO?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th October 2008, 05:13 PM   #9
Speakerholic
Cal Weldon's Avatar
SDX7? Is that not a 6.5"?
Old 19th October 2008, 05:27 PM   #10
frugal-phile(tm)
planet10's Avatar
classed as a 7"
dave
12" "guitar" driver in Audio Speakers jwhit67 Multi-Way 4 11th February 2008 02:47 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
UK source of inexpensive 3" or 4" driver - high efficiency sreten Full Range 9 23rd November 2005 03:15 PM
Is it worth buying cheapy 15" driver or expensive 12"? VEC7OR Subwoofers 7 26th February 2005 10:09 PM
Page generated in 0.13640 seconds (67.77% PHP - 32.23% MySQL) with 11 queries
