Hi guys.
I just finished tweaking my Jamo xovers. I have rebuilt them on a piece of board mounted externally, hard-wired to do away with the pcb that was originally fitted. Unfortunately I managed to snap the wire in the coil on the tweeter on one of them ![]() Does anyone know the value of these coils please? I need to buy a couple of replacements, but don't have an inductance meter. btw, I did solder the wire back together using some Mundorf Supreme solder, but the treble from this channel is veiled compared to the other side. Cheers, Lee.
#2 | |
Really recheck all schematic connections for errors and watch the coils orientation to one another and/or spacing to reduce cross couplings.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 | |
Hi, thanks for the reply. I have re-checked all connections and joint several times. I have removed the coils from the circuit and now both speakers are sounding the same. I think I've monged the faulty coil removing it from the original board, as they were glued on. I melted the glue as best I could, but... Cheers, Lee.
#4 | |
Pretty sure on this, but I think wonked coils are better than no coils....Use ty wraps and remove the bobbin slowly to get better access? Hell, chewing gum and bailing wire (duct tape) might be useful.
#5 |
Yeah, you're right. The xover's for treble are 3rd order, which is a pain trying to work out the value of the coils. I am running them 1st order to make do at the moment with a 10uF cap which I think brings them in at 2500Hz.
I will have a closer inspection tomorrow at the bad coil, which has a lower dcr than the good one from the other speaker. It maybe some of the turns are shorted together and I can fix it. I have posted the schematic, just in case anyone can think of some improvements/tweaks I could implement. I have upgraded all the components except the coils so far. Cheers, Lee.
#6 | |
Dave |
#7 | |
I have been playing about with the values in LSP Cad Lite trying to calculate the coil value. I actually got pretty close (for a complete speaker noob) at 0.20mH. Thanks again, Lee.
| Jamo D830 (Concert 8) crossover | Eccu | Multi-Way | 15 | 14th May 2012 06:42 AM |
| Jamo Concert 7 | kele1975 | Multi-Way | 2 | 28th April 2010 09:51 PM |
| Jamo Concert Vii | JensRasmussen | Multi-Way | 3 | 8th March 2008 11:38 AM |
| different xover q-values | Snooze | Multi-Way | 5 | 7th March 2002 08:01 AM |
| Page generated in 0.10809 seconds (76.77% PHP - 23.23% MySQL) with 11 queries |
