I have an idea that uses a CSS FR125S in a 7ltr sealed box and two Extremis 6.8 in series vented and tuned to ~25 to 30hz, 35ltr box.
They will be crossed at ~250hz (2nd order on FR125 and 1st on extremis). I may add a super tweeter later on if necessary. This is for movies and music useage...oh and I like what would be considered Heavy Metal mostly Any thoughts, suggestions for myself? I have the drivers, just would like to do something different with them. |
#2 |
frugal-phile(tm)
Sure that will woek.
My mains are similar idea (Fonken+2 SDX7eN per side). I XO at 100 Hz axtive. I would suggest active XO, even if you push the XO up as high as you are considering. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
So how low would/could you go with the FR125?
I thought about active, but that's more money again The basic idea with this design is to have something new/different but without spending too much extra money. |
#4 | |
frugal-phile(tm)
dave
#5 | |
I'm not sure I follow your meaning.... To actively crossover I'd need to bi-amp, no? That now requires two amps plus a pre-amp and the active crossover. Not exactly what I had in mind with cheap |
#6 |
frugal-phile(tm)
Indeed, but if you can add pre-out, power-in on your integrated/receiver, pick up a 2nd hand almost anything (or build a chipamp), and use a PLLXO (or integrate a low pass into the chip-amp), you can come out pretty cheap. From close to free to as much money as you want to spend (a good junk box of parts helps)
dave
#7 | |
thanks for your input. |
#8 | |
frugal-phile(tm)
dave
#9 |
Thanks, I'll look him up.
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Page generated in 0.11806 seconds (67.93% PHP - 32.07% MySQL) with 10 queries |
