what mid is used in kef coda 7? isit B110?
Old 18th October 2008, 10:49 AM   #1
anton-sa is offline anton-sa  South Africa
Default what mid is used in kef coda 7? isit B110?
Hi All,
i've been searching the internet hi and low.... ok here's the thing, i compete in iasca soundquality vehicle autosound competitions, i ripped a set of woofers from a set of kef coda 7 speakers i had, and i have placed and won every competition i enter ever since!
The others all use 6" woofers in their vehicles to get more midbass, little do they know that in most vehicles u cannot build large enough enclosures (kickpanels) for 6" woofers.
The woofers i have are 5.25" treated paper cone, the closest i can find and the woofer that seems the closest match seems to be the KEF B110.... the photos everything looks alike.
except for one thing, mine have a DC resistance of 3.9ohm... while the datasheets i find list over 7ohm for dc resistance... i know the kef coda 7's were mid 90's speakers...
i also know that there were as many as 3 or 4 variants of the B110 midwoofer...
i could be wrong, but like i said the B110 woofer from kef seems to be the closest match....
i want to get the T/S parameters/datasheet for the woofer, im now running multiple amplifiers in my vehicles and have ditched the passive crossovers i used (also from kef coda 7 cabinets)
running fully active variable 24db/oct crossovers...
i need to set the crossover point, now i know the kef coda 7's were originally 3500hz presumably at 6db/oct
its for example no use...oh im running 2 way in front... its for example no use crossing over my tweeter @ 4000hz if the kef mids cant reach that high...
i will tune to 3.5khz for now...perhaps crossover the tweeters then @ 3k.
any info or suggestions would be GREATLY appreciated!!!!
if my assumption of the B110 woofer is correct, a response graph would be great...because if its frequency response is upto 3500hz surely there is a rolloff at that point,
then perhaps cross over point of 3k would be better?
cheers
anton
cape town
south africa
Old 20th October 2008, 12:37 PM   #2
Default keep it goin
bump just to keep this thread alive
Old 20th October 2008, 02:24 PM   #3
diyAudio Member RIP
The drivers in the Kef Coda 7 are nothing like the Kef B110.
I think they were Indian made Vifa/Peerless drivers or very similar.
http://www.tymphany.com/files/produc...C14WG49-04.pdf
Is the sort of thing.
/sreten.
Old 20th October 2008, 03:27 PM   #4
Default hi there
hi there
here is how the woofer looks
looks remarkeably like a b110 ? but then just cause the basket is the same and the cone i suppose it doesnt mean anything...
the basket of the 1st gen b110 looks a little different, but look at the 3rd gen b110?
i think there was a 4th gen b110...
btw, the pdf of the woofer you sent me looks totally different to this..
how sure are you?
Old 20th October 2008, 04:22 PM   #5
speakerdoctor is offline speakerdoctor  United States
These sure do bare a remarkable resemblence to the 4 ohm Polydax HIF 17 JS 2 CA 12 bass/mid used in the famous Spica TC50 and 50i speakers. OD of the frame is 172 mm if that helps. Spica also coated the cones themselves.
The bad news is this woofer is no longer available from Audax, Polydax's new owner. You'll have to try and find some on ebay if that looks to be a good match.
"It's all about the music!"
Old 20th October 2008, 04:40 PM   #6
diyAudio Member RIP
The B110 is bextrene, these drivers appear to be coated paper.
http://www.speakerbits.com/net/catal...aspx?id=VF130C
/sreten.
Old 20th October 2008, 05:02 PM   #7
Default hi there
hi there,
the Re (electrical resistance) of these drivers of mine is 3.9ohm
all the other drivers seem to be 7.x or 8.x ohm
Old 20th October 2008, 05:05 PM   #8
look at the basket of my speakers, they are wider than the magnet... much like b110
please note.. me not argueing just trying to work out the mystery
the kef coda 7's are gems of speakers.. the midwoofer is also a semi long throw design..
thats y they can handle the punishment...
Old 22nd October 2008, 01:30 AM   #9
elac310 is offline elac310  France
elac310's Avatar
I almost agree with SpeakerDoctor. Looks like an Audax to me too, but perhaps of the type HIF13something. There have been endless variants built on this basis and they were often used by British manufacturers, including I think in the famous LS3/5A (or some of its commercial clones). Could be that Kef too have used Audax. For obsolete models like these, I would try my chance on ebay.fr or ebay.de where there is quite a lot of old speakers of this kind to be found.
Good luck!
(PS: a search with HIF13 on the Internet gives quite many results).
Old 22nd October 2008, 09:58 AM   #10
Default hi
hi there
Thx 4 the info i will search my drivers are not broken or faulty infact ive got 2 sets of them one in the car and a spare set. The tech info is needed to optimise them and to optimise crossover points etc
what mid is used in kef coda 7? isit B110?Hide this!Advertise here!
2N5566 on CODA CLX preamplifier ANADIGIT Pass Labs 20 18th January 2016 10:59 AM
KEF B110 SP1057 anybody have one (or 2)? larezreyes Multi-Way 16 3rd June 2014 09:27 AM
KEF SP1380 6 ohm B110 ANTHONY2181 Multi-Way 16 15th December 2008 06:52 AM
Does CODA CLX = Threshold Fet ? ANADIGIT Pass Labs 0 12th December 2008 06:19 AM
Coda Continuum for repairs in Toronto rmihai Swap Meet 2 30th May 2005 07:12 PM
Copyright ©1999-2017 diyAudio
