Today I purchased 2 Swanpeaker M5A drivers at my local dealer. I'm planning a 2 way config with some Visaton G35FFL tweeters I have lying around.
Here is the datasheet of the driver: http://www.swanspeaker.com/product/htm/view.asp?id=76 If I plan a non vented box, what volume should it be? 11.2 of 10 L ? If I plan a vented box, where should I place the vent pipe? What lenght should it be? How wide? Any recommandations are very welcome. |
#2 |
Usually the volume of the closed box is about half of the vented.
If you make the recommended enclosure (10L vented), use the formula to calculate vent length: http://www.linearteam.dk/default.asp...ventcalculator Use the recommended tuning frequency(Fb=50Hz)! The vent diameter should be about 2". Place the vent to the rear baffle. It should be level with the tweeter. Here is a similar project: Manganese-14 http://home.mchsi.com/~iowadiy2007/superbudget.html |
#3 |
I've tried vents in different places and always seem to find that the closer they are to the woofer the better they work.
In a closed box, volume is not very critical like it is in a vented box. If you don't feel confident to tune a vented box, then just make it closed. A mistuned vented box can sound bad far easier than the wrong volume of a closed box. Use a closed box and some subs and you'll be happy. I only use closed boxes. |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Newbie: how to calculate pot for volume control | wdekler | Solid State | 7 | 22nd March 2005 08:40 PM |
| Newbie question: passive volume control mod for DAC | Ichabod | Analogue Source | 0 | 4th November 2004 01:34 PM |
| Newbie Q: Control volume of 5 amps | TheBat | Chip Amps | 15 | 2nd August 2004 08:59 AM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
| Page generated in 0.11783 seconds (51.73% PHP - 48.27% MySQL) with 10 queries |
